Subject: Re: registerRecordDeviceDriver fails at registryRecordTypeFind
To: Matt Rippa <[email protected]>
Date: Thu, 16 Feb 2012 13:48:38 +0100
This is a typical symptom when your EPICS base binaries do not match the dbd files. For example when you load a EPICS 3.14.12 dbd file into a EPICS 3.14.8 IOC.
Dirk
Matt Rippa wrote:
I have a new vxworks(5.5.1) IOC (3.14.12.1) application crashing
on startup at the registry stage. I suspect something like a
missing DBD entry in my Makefile. I've rebuilt everything
referenced in my configure/RELEASE file from epics-base to my
application.
Is there an easy way to get more information before the crash?
Thanks for the help,
Matt
ld 0,0, "gmosdc.munch"
BSP routine sysAtReboot() not found, epicsExit() will not be
called by reboot.  For reduced functionality, call
    rebootHookAdd(epicsExitCallAtExits)
value = 1038310096 = 0x3de35ad0 = ipAddrToAsciiEnginePrivate
type_info node + 0xb40
# Work around to allow epics to close network connections
# nicely on exit. See:
# http://www.aps.anl.gov/epics/tech-talk/2008/msg00259.php
value = 0 = 0x0
cd top
value = 0 = 0x0
dbLoadDatabase("dbd/gmosdc.dbd",0,0)
value = 0 = 0x0
gmosdc_registerRecordDeviceDriver(pdbbase)
program
Exception current instruction address: 0x00000004
Machine Status Register: 0x
0008b030
Condition Register: 0x8000208420c01c
 vxTaskEntry    +68 : shell ()
1c943c shell          +190: 1c9468 ()
1c9668 shell          +3bc: execute ()
1c97ec execute        +d8 : yyparse ()
1e5ea4 yyparse        +71c: 1e423c ()
1e43c0 yystart        +96c: gmosdc_registerRecordDeviceDriver ()
3db54210 gmosdc_registerRecordDeviceDriver+b8 :
registerRecordTypes ()
3dc246c0 registerRecordTypes+ac : registryRecordTypeFind ()
3dc243a8 registryRecordTypeFind+28 : 4 ()
shell restarted.
Re: registerRecordDeviceDriver fails at registryRecordTypeFind Andrew Johnson
registerRecordDeviceDriver fails at registryRecordTypeFind Matt Rippa
Prev: Re: epics-arduino Noboru Yamamoto
Next: Re: registerRecordDeviceDriver fails at registryRecordTypeFind Andrew Johnson
Prev: Re: registerRecordDeviceDriver fails at registryRecordTypeFind Matt Rippa
