1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: registerRecordDeviceDriver fails at registryRecordTypeFind
To: [email protected], Matt Rippa <[email protected]>
Date: Thu, 16 Feb 2012 10:57:35 -0600
On 2012-02-16 Dirk Zimoch wrote:
> This is a typical symptom when your EPICS base binaries do not match the
> dbd files. For example when you load a EPICS 3.14.12 dbd file into a
> EPICS 3.14.8 IOC.
... which is why makeBaseApp applications run checkRelease at build time to
compare the RELEASE file paths for the application with those of all its
support modules.  If you disable checking by setting CHECK_RELEASE=NO you're
arming your own foot-gun (recent versions of Base do print a warning in this
case; if I need to disable the check I *always* set it to WARN instead of NO).
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
registerRecordDeviceDriver fails at registryRecordTypeFind Matt Rippa
Re: registerRecordDeviceDriver fails at registryRecordTypeFind Dirk Zimoch
Prev: Re: registerRecordDeviceDriver fails at registryRecordTypeFind Dirk Zimoch
Next: EDM segmentation fault in colorInfoClass Shankar, Murali
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Modbus/serial using Stream? Ralph Lange
