1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Connection to Siemens S7 PLC
To: EPICS Tech Talk <[email protected]>
Date: Tue, 21 Feb 2012 15:47:22 +0100
On 21.02.2012 13:13, Konrad Gajewski wrote:
> Hello everybody,
> I'm new to EPICS and I am planning  to control Siemens Simatic S7-200
> PLC. I have looked in EPIC documentation and found at least two ways
> to connect the PLC:
> 1. via MODBUS (Asyn) driver over the serial connection (using Siemens
> MODBUS RTU library)
> 2. using S7plc driver via TCP/IP and a CP 243-1 Ethernet module.
> The programming of the PLC is done using Step-7 Micro/WIN V4.0.
> Unfortunately I can't open the example STEP 7 PLC project  (for S7plc
> driver) in Step-7 Micro/WIN.
> Do you have any experience with such a configuration or maybe with
> S7-1200? Are there any better options?
Using an OPC server (Siemens or third party vendor) and OPC Device
Support is a third alternative. [1]
Introduces an additional protocol layer (and IOCs running Windows), but
lets you integrate many different PLCs from different vendors in a
streamlined, uniform way.
At HZB, we were evaluating S7plc, a CAN field bus interface and OPC
Device Support, and decided to make the OPC option our future standard
for PLC integration.
~Ralph
[1] http://www-csr.bessy.de/control/SoftDist/OPCsupport/
> Thanks,
>   Konrad
Connection to Siemens S7 PLC Konrad Gajewski
Prev: Re: Connection to Siemens S7 PLC Pavel Masloff
Next: norgren valve island Pierrick Hanlet
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Connection to Siemens S7 PLC Mark Rivers
