Hello everybody,
I'm new to EPICS and I am planning to control Siemens Simatic S7-200
PLC. I have looked in EPIC documentation and found at least two ways to
connect the PLC:
1. via MODBUS (Asyn) driver over the serial connection (using Siemens
MODBUS RTU library)
2. using S7plc driver via TCP/IP and a CP 243-1 Ethernet module.
The programming of the PLC is done using Step-7 Micro/WIN V4.0.
Unfortunately I can't open the example STEP 7 PLC project (for S7plc
driver) in Step-7 Micro/WIN.
Do you have any experience with such a configuration or maybe with
S7-1200? Are there any better options?
Konrad
Konrad Gajewski
Senior Research Engineer
Uppsala University Tel: +46-18-4713888
The Svedberg Laboratory mailto:[email protected]
Box 533, S-751 21 Uppsala, Sweden
http://www.tsl.uu.se/
- Re: Connection to Siemens S7 PLC Pavel Masloff
- Re: Connection to Siemens S7 PLC Ralph Lange
- RE: Connection to Siemens S7 PLC Mark Rivers
- RE: Connection to Siemens S7 PLC Mueller, Joachim
- Re: Connection to Siemens S7 PLC Rod Nussbaumer
Re: Problems with priorities in epicsThreadCreate (part of the EPICS OSI software layer) Andrew Johnson
<2012>
2025
2026
Re: Missing patch file? Andrew Johnson
<2012>
2025
2026
