Subject: Re: Problems with priorities in epicsThreadCreate (part of the EPICS OSI software layer)
To: [email protected]
Cc: Eric Norum <[email protected]>, Goetz Pfeiffer <[email protected]>
Date: Mon, 20 Feb 2012 15:46:29 -0600
Hi Goetz,
On 2012-02-20 Eric Norum wrote:
> How about calling the RTEMS rtems_task_set_priority routine from the
> beginning of your new thread?
I think I prefer Eric's suggestion to adding anything to the epicsThread API.
For each particular OS you will already need an OS-specific numeric priority,
so you'll have to have OS-specific code in the source file anyway.  In that
case you can just call the OS-specific API to change the new thread's
priority.  For vxWorks and RTEMS that would mean adding something like this:
#if defined(vxWorks)
    taskPrioritySet(0, 66);
#elif defined(RTEMS)
        rtems_task_priority old;
        rtems_task_set_priority(RTEMS_SELF, 66, &old);
#endif
Now it's obvious that the this is OS-specific code, and the thread priority
can be easily set to whatever is appropriate for the OS.
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
Re: Problems with priorities in epicsThreadCreate (part of the EPICS OSI software layer) Goetz Pfeiffer
Re: Problems with priorities in epicsThreadCreate (part of the EPICS OSI software layer) Eric Norum
Prev: Re: Problems with priorities in epicsThreadCreate (part of the EPICS OSI software layer) Eric Norum
Next: Connection to Siemens S7 PLC Konrad Gajewski
Next: Re: Problems with priorities in epicsThreadCreate (part of the EPICS OSI software layer) Goetz Pfeiffer
