Hi Andrew,
hi Eric,
thank you for your reply.
Adding operating system dependent code to my application to set the
priority would be a solution of course.
However, the intention of EPICS OSI is that I don't have to do that. If
there was a possibility to
specify the thread priority directly, I wouldn't have to include system
headers or call system functions
directly. If EPICS OSI was changed or extended, my code would look like
this:
#if defined(vxWorks)
#define GPS_WRITER_PRIO 67
#elif defined(RTEMS)
#define GPS_WRITER_PRIO 123
#endif
epicsThreadCreate("mC Writer", GPS_WRITER_PRIO,
epicsThreadGetStackSize(epicsThreadStackSmall),
(EPICSTHREADFUNC) gps_writer, NULL))
Isn't this nicer than having to call taskPrioritySet or
rtems_task_set_priority directly as
in your quoted mail below ?
The way epicsThreadCreate in EPICS OSI handles priorities at least in
the vxWorks and RTEMS
implementation seems to be a design flaw for me. Why not fix it ?
Greetings,
Goetz
On 02/20/2012 10:46 PM, Andrew Johnson wrote:
Hi Goetz,
On 2012-02-20 Eric Norum wrote:
How about calling the RTEMS rtems_task_set_priority routine from the
beginning of your new thread?
I think I prefer Eric's suggestion to adding anything to the epicsThread API.
For each particular OS you will already need an OS-specific numeric priority,
so you'll have to have OS-specific code in the source file anyway. In that
case you can just call the OS-specific API to change the new thread's
priority. For vxWorks and RTEMS that would mean adding something like this:
taskPrioritySet(0, 66);
rtems_task_priority old;
rtems_task_set_priority(RTEMS_SELF, 66,&old);
#endif
Now it's obvious that the this is OS-specific code, and the thread priority
can be easily set to whatever is appropriate for the OS.
- Andrew
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführerin: Prof. Dr. Anke Rita Kaysser-Pyzalla
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
- Best pratices for compiling dbd files for asyn base device support Abadie Lana
- Re: Problems with priorities in epicsThreadCreate (part of the EPICS OSI software layer) Andrew Johnson
- Problems with priorities in epicsThreadCreate (part of the EPICS OSI software layer) Goetz Pfeiffer
- Re: Problems with priorities in epicsThreadCreate (part of the EPICS OSI software layer) Eric Norum
RE: Connection to Siemens S7 PLC Mueller, Joachim
<2012>
2025
2026
<2012>
2025
2026
