1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problems with priorities in epicsThreadCreate (part of the EPICS OSI software layer)
To: Goetz Pfeiffer <[email protected]>
Cc: Eric Norum <[email protected]>, [email protected]
Date: Wed, 22 Feb 2012 15:37:59 -0600
Hi Goetz,
On 2012-02-22 Goetz Pfeiffer wrote:
> However, the intention of EPICS OSI is that I don't have to do that. If
> there was a possibility to
> specify the thread priority directly, I wouldn't have to include system
> headers or call system functions
> directly.
We give you the ability to set thread priorities, but your problem is that the
range of OS priorities we allow you to use is narrower than you want.  I'm not
sure why you need to go outside of the standard range, but it has to be due to
interaction with some other software which is not using the OSI APIs to set
its thread priorities.  Our APIs provide an abstraction of the underlying OS
API and as long as you stay within our model the abstraction is sufficient,
but in your case the outside world is leaking into our model.
Adding an OS-specific thread priority argument to our API would make it easier
for you to do what you need, but doing so pollutes our abstract model, and I
prefer to try and preserve that model.
> If EPICS OSI was changed or extended, my code would look like
> this:
> #if defined(vxWorks)
>    #define GPS_WRITER_PRIO 67
> #elif defined(RTEMS)
>    #define GPS_WRITER_PRIO 123
> #endif
> epicsThreadCreate("mC Writer", GPS_WRITER_PRIO,
>                    epicsThreadGetStackSize(epicsThreadStackSmall),
>                    (EPICSTHREADFUNC) gps_writer, NULL))
> Isn't this nicer than having to call taskPrioritySet or
> rtems_task_set_priority directly as
> in your quoted mail below ?
If you want the C source to look nice you could put this into a header file
instead:
    #include <taskLib.h>
    #define setWriterThreadPriority taskPrioritySet(0, 67)
    #include "rtems.h"
    #define setWriterThreadPriority do { \
        rtems_task_priority old; \
        rtems_task_set_priority(RTEMS_SELF, 123, &old); \
    } while (0)
#else
    #define setWriterThreadPriority (void) 0
#endif
Now your gps_writer function just has to add this line:
setWriterThreadPriority;
> The way epicsThreadCreate in EPICS OSI handles priorities at least in
> the vxWorks and RTEMS
> implementation seems to be a design flaw for me. Why not fix it ?
That is only true if you expect the API to be able to create threads at all of
the underlying OS priority levels.  The OSI abstract model doesn't support
that on vxWorks or RTEMS because we don't want our applications to use
inappropriate task priorities — we have had problems here at APS in the past
with tasks running above tNetTask for example, and this model was deliberately
designed to make that harder to do.  If you want to go outside our supported
priorities you can, but not using the epicsThread API.
Note that Klemen Zagar's issue about the mapping between OSI and Posix
priority values was fixed in R3.14.12.2, and on Posix architectures we do now
make the full OS priority range available since a single process can't crash
the whole machine.  I am still interested in some of Klemen's changes, but not
the epicsThreadSetPosixPriority...() functions.
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
Problems with priorities in epicsThreadCreate (part of the EPICS OSI software layer) Goetz Pfeiffer
Re: Problems with priorities in epicsThreadCreate (part of the EPICS OSI software layer) Andrew Johnson
Re: Problems with priorities in epicsThreadCreate (part of the EPICS OSI software layer) Goetz Pfeiffer
Prev: Re: QT-based tools: Expressions of interest requested Jane Richards
Next: Alarm for noisy readback channel Paul Nord
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Best pratices for compiling dbd files for asyn base device support Mark Rivers
Next: Re: Problems with priorities in epicsThreadCreate (part of the EPICS OSI software layer) Goetz Pfeiffer
