1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Connection to Siemens S7 PLC
To: Konrad Gajewski <[email protected]>
Cc: [email protected]
Date: Wed, 22 Feb 2012 09:19:58 -0800
At TRIUMF, we are using our own driver to talk to 400-series Siemens PLCs. It uses asyn, and was modeled after Mark Rivers' modbus PLC driver. The underlying communications protocol is the Siemens FETCH/WRITE protocol over TCP/IP.
Rod Nussbaumer
ISAC Controls, TRIUMF
Vancouver, Canada
Konrad Gajewski wrote:
Hello everybody,
I'm new to EPICS and I am planning to control Siemens Simatic S7-200
PLC. I have looked in EPIC documentation and found at least two ways to
connect the PLC:
1. via MODBUS (Asyn) driver over the serial connection (using Siemens
MODBUS RTU library)
2. using S7plc driver via TCP/IP and a CP 243-1 Ethernet module.
The programming of the PLC is done using Step-7 Micro/WIN V4.0.
Unfortunately I can't open the example STEP 7 PLC project (for S7plc
driver) in Step-7 Micro/WIN.
Do you have any experience with such a configuration or maybe with
S7-1200? Are there any better options?
Konrad
AW: Connection to Siemens S7 PLC Rekow Jens
Connection to Siemens S7 PLC Konrad Gajewski
Prev: RE: Best pratices for compiling dbd files for asyn base device support Mark Rivers
Next: Re: CSS X-Y Graph Michael Davidsaver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Connection to Siemens S7 PLC Mark Rivers
Next: AW: Connection to Siemens S7 PLC Rekow Jens
