Hi Lana,
I am not sure I understand your suggestion.
> Currently when a driver is using EPICS device support via asyn, it has these lines in the Makefile
> XX_DBD += base.dbd
> XX_DBD += asyn.dbd
Actually that statement is not really correct. The correct statement is:
"Currently when an APPLICATION is using EPICS device support via asyn, it has these lines in the Makefile"
There is a big difference. An application may load many drivers. Some will support a specific asyn interface (e.g. asynOctet, asynInt32, etc.) and some will not.
> It is fine when your driver supports all of them, but not if your driver supports part of them.
That is not true. There is no harm in loading all of the device support that is in devEpics.dbd, which is included by asyn.dbd. It just adds a few kB to your application. It does not lead to any problems if there happen to be no drivers in your application that supports a particular record type or asyn interface. If you are having problems because your driver does not support a particular interface, then something is wrong with the way you are building your application or something. If you are receiving an error please include it in your message.
asyn.dbd contains the following:
registrar(asynRegister)
registrar(asynInterposeFlushRegister)
registrar(asynInterposeEosRegister)
# The following ties this to EPICS records.
# Applications which wish to use ASYN without EPICS
# records can comment out the following lines.
include "asynRecord.dbd"
include "devEpics.dbd"
driver(drvAsyn)
If you really want to exclude things from asyn.dbd (which as I said, I don't see any reason to do) then simply don't include asyn.dbd, just add whatever lines from asyn.dbd that you want in your application's dbd file. For example include all lines above except devEpics.dbd, etc.
From: [email protected] [[email protected]] on behalf of Abadie Lana [[email protected]]
Sent: Wednesday, February 22, 2012 4:41 AM
To: [email protected]
Subject: Best pratices for compiling dbd files for asyn base device support
Hi all
I would like to collect some feedback on the best things to include proper DTYP information in the dbd file when using asyn.
XX_DBD += base.dbd
XX_DBD += asyn.dbd
This will result in a dbd for the driver which includes all the combination record type/DTYP from asyn (referring lines to device(XXX)). It is fine when your driver supports all of them, but not if your driver supports part of them.
So one idea would be to modify the asyn.dbd and comment the include devEpics and add another dbd which manually lists the supported interfaces per device support.
Does it sounds reasonable ? any other feedback?
Thanks
Lana
- RE: Best pratices for compiling dbd files for asyn base device support Abadie Lana
- Problems with priorities in epicsThreadCreate (part of the EPICS OSI software layer) Goetz Pfeiffer
- Re: Problems with priorities in epicsThreadCreate (part of the EPICS OSI software layer) Eric Norum
- Re: Problems with priorities in epicsThreadCreate (part of the EPICS OSI software layer) Andrew Johnson
- Re: Problems with priorities in epicsThreadCreate (part of the EPICS OSI software layer) Goetz Pfeiffer
- Best pratices for compiling dbd files for asyn base device support Abadie Lana
RE: Connection to Siemens S7 PLC Mark Rivers
Re: Connection to Siemens S7 PLC Rod Nussbaumer
<2012>
2025
2026
<2012>
2025
2026
