On 02/21/2012 07:17 PM, Andrew Johnson wrote:
Hi Michael,
On 2012-02-21 Michael Davidsaver wrote:
I too have had trouble doing this. I was able to setup a rule to set
the buffer size from the NORD field of a waveform record. The result
was that, when the size was reduced, the start of the waveform was
removed instead of the end. So not very useful.
Also note that the NORD field of a waveform record does not get monitors
posted on it unless there is device support that explicitly does that, so this
wouldn't necessarily work too well anyway (you could forward-link the waveform
record to a longin that reads the NORD field and use that instead though).
I was aware of this, but tried anyway to see what would happen. Since I
do see an effect I think it must be issuing a get periodically.
- CSS X-Y Graph John Dobbins
- Re: CSS X-Y Graph Michael Davidsaver
- Re: CSS X-Y Graph Andrew Johnson
Re: Connection to Siemens S7 PLC Rod Nussbaumer
Re: QT-based tools: Expressions of interest requested Jane Richards
<2012>
2025
2026
RE: CSS X-Y Graph Mark Rivers
RE: CSS X-Y Graph Chen, Xihui
<2012>
2025
2026
