As Franck said, ITER has standardized on the S7 (300) series and the
Step 7 Professional Edition software (Windows). We are using the ITER
configuration here with an S7-3xx and an EPICS Linux-based IOC. We
also recently got an S7-1200 which we are trying to get working with
the ITER software .... not there yet. We will announce any success on
this.
-ps
On Wed, Feb 22, 2012 at 07:07, Pavel Masloff <[email protected]> wrote:
> Hello all,
> Concerning Dirk's s7plc driver (SLS) which is written for linux only, has
> anyone tried to rewrite it for windows?
> I am not that expert in drivers development, but I would be grateful if
> anyone could help me.
> >From what I can see, there are some header files (and corresponding
> libraries/functions) which are linux specific. For example,
> <unistd.h>,<sys/socket.h>, <netinet/in.h>. Perhaps, <winsock2.h> might do
> the trick?
> Maybe someone has already tried to port s7plc to Windows platform?
> On Wed, Feb 22, 2012 at 1:10 PM, Mueller, Joachim <[email protected]>
> wrote:
>> Hi,
>> just a few thoughts about the S7. It is not possible to open a Step7
>> Project for the S7-300
>> or S7-400 with Step7 MicroWin. These system do not have anything in common
>> than the
>> name and the vendor. S7-200 has a different architecture than the 300/400
>> system. And
>> therefore a completely different programming environment.
>> I have not tried yet, but I think the S7plc driver should also work with a
>> S7-1200 System
>> because it is also TCP/IP.
>> With the CP 243-1 on a S7-200 it should also work, but you cannot use the
>> example project
>> delivered with the S7plc software.
>> Greetings, Joachim
>> Joachim Mueller, Dipl.-Ing.(FH) Deutsches
>> Elektronen-Synchrotron (MKK4)
>> phone: +49-40-8998-2562
>> Notkestr. 85
>> fax: +49-40-8994-4305
>> 22607 Hamburg
>> e-mail: [email protected]
>> Germany
>> >-----Original Message-----
>> >From: [email protected] [mailto:tech-talk-
>> >[email protected]] On Behalf Of Konrad Gajewski
>> >Sent: Tuesday, February 21, 2012 1:14 PM
>> >To: [email protected]
>> >Subject: Connection to Siemens S7 PLC
>> >Hello everybody,
>> >I'm new to EPICS and I am planning to control Siemens Simatic S7-200
>> >PLC. I have looked in EPIC documentation and found at least two ways to
>> >connect the PLC:
>> >1. via MODBUS (Asyn) driver over the serial connection (using Siemens
>> >MODBUS RTU library)
>> >2. using S7plc driver via TCP/IP and a CP 243-1 Ethernet module.
>> >The programming of the PLC is done using Step-7 Micro/WIN V4.0.
>> >Unfortunately I can't open the example STEP 7 PLC project (for S7plc
>> >driver) in Step-7 Micro/WIN.
>> >Do you have any experience with such a configuration or maybe with
>> >S7-1200? Are there any better options?
>> >Thanks,
>> > Konrad
>> >Konrad Gajewski
>> >Senior Research Engineer
>> >Uppsala University Tel: +46-18-4713888
>> >The Svedberg Laboratory mailto:[email protected]
>> >Box 533, S-751 21 Uppsala, Sweden
>> >http://www.tsl.uu.se/
> Best regards,
> Pavel Maslov, MS
> Controls Engineer at Pulsed power Lab
> Efremov Institute for Electro-Physical Apparatus
> St. Petersburg, Russia
> Mobile: +7 (951) 672 22 19
> Phone: +7 (812) 461 01 01
- AW: Connection to Siemens S7 PLC Rekow Jens
- Connection to Siemens S7 PLC Konrad Gajewski
- RE: Connection to Siemens S7 PLC Mueller, Joachim
- Re: Connection to Siemens S7 PLC Pavel Masloff
RE: QT-based tools: Expressions of interest requested ian.gillingham
RE: CSS X-Y Graph Chen, Xihui
<2012>
2025
2026
<2012>
2025
2026
