1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CSS workspace lock, prompt Re: BOY FAQ
Date: Fri, 02 Mar 2012 16:29:39 +0100
Thanks a lot, Kay!
I know different labs handle their operator accounts very differently,
but I would still have to be convinced that scrambling the workspace is
a reasonable option in any of these setups.
On 02.03.2012 16:06, Kasemir, Kay wrote:
> In case your workspace _does_ get corrupted,
> in many cases all you need to do is:
> Delete the ".metadata" directory.
> All your files will still be there.
> What's lost is
> * the last window location - no big deal.
Unless you are on a 4-wide-screen console with ~10 windows open, each
showing a specific set of panels.
In that case: Yes big deal.
> * your preferences modifications
>   - should also not be a big deal because ideally
>     the product for your site has all essential settings
>     "built in", or you use a -pluginCustomization file
>     that has them, so end users don't need to bother
>     with EPICS CA addr list, archive data sources, ...
You also lose the setup of all imported projects from shared locations,
linked directories, etc.
In my case, the workspace is practically empty except for ".metadata",
so the loss is almost complete.
Thanks again,
~Ralph
Re: CSS workspace lock, prompt Re: BOY FAQ Kasemir, Kay
Prev: CSS workspace lock, prompt Re: BOY FAQ Kasemir, Kay
Next: Re: CSS workspace lock, prompt Re: BOY FAQ Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
