1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: "Size of symbol changed" warnings building EPICS Base 3.14.12.2
To: "J. Lewis Muir" <[email protected]>
Cc: [email protected]
Date: Fri, 2 Mar 2012 12:47:49 -0600
Hi Lewis,
On 2012-03-02 J. Lewis Muir wrote:
> The build host is running RHEL Client 5.7.  The VxWorks Tornado
> 2.0.2 environment is from the APS.
Wind River have never officially supported compiling code for vxWorks 5.x on a
linux-x86 system, and I don't do test builds on version 5.4.2 very often,
although I do use 5.5.2 quite a bit.  Note that EPICS 3.15 will not support
vxWorks 5.4.2 because the C++ compiler is too old; you will have to upgrade to
vxWorks 5.5.2 to run that.  I recently published a linux-x86 toolset built on
RHEL 5.6 for vxWorks 5.5.2 using the very latest Wind River GCC sources.
I have just built the tip of the 3.14 branch for ppc604 on vxWorks 5.4.2 using
my RHEL 6.2 x86_64 workstation without getting those warnings.  I don't know
if I'm using exactly the same tools as you though.  This is the log from
compiling the src/db/test/O.vxWorks-ppc604 directory:
/usr/local/vw/tornado202p1/host/x86-linux/bin/ccppc -c -DCPU=PPC604 -
DvxWorks=vxWorks -include /usr/local/vw/tornado202p1/target/h/vxWorks.h -O2
-Wall -mcpu=604 -mstrict-align -mno-implicit-fp -fno-builtin -MMD -I. -
I../O.Common -I. -I.. -I../../../../include/os/vxWorks -I../../../../include
-I/usr/local/vw/tornado202p1/target/h ../callbackTest.c
/usr/local/vw/tornado202p1/host/x86-linux/bin/ldppc -r -o callbackTest  -
L../../../../lib/vxWorks-ppc604/          -
L/usr/local/vw/tornado202p1/host/x86-linux/powerpc-wrs-vxworks/lib
callbackTest.o -ldbIoc -ldbStaticIoc -lca -lCom
/usr/local/vw/tornado202p1/host/x86-linux/bin/nmppc callbackTest >
callbackTest.nm
perl ../../../../bin/linux-x86_64/munch.pl -o callbackTest_ctdt.c
callbackTest.nm
DvxWorks=vxWorks -include /usr/local/vw/tornado202p1/target/h/vxWorks.h -O2 -
Wall -mcpu=604 -mstrict-align -mno-implicit-fp -fno-builtin -MMD -fdollars-in-
identifiers -I. -I../O.Common -I. -I.. -I../../../../include/os/vxWorks -
I../../../../include -I/usr/local/vw/tornado202p1/target/h
callbackTest_ctdt.c
/usr/local/vw/tornado202p1/host/x86-linux/bin/ldppc -r -o callbackTest.munch
callbackTest_ctdt.o callbackTest
Installing created file ../../../../bin/vxWorks-ppc604/callbackTest.munch
> Searching the web I found this:
>   http://gcc.gnu.org/ml/gcc-help/2001-03/msg00167.html
> I don't know if that helps.
A little...
> Are these warnings a problem?
I suspect not, but I don't know for sure.
> I happened to be compiling with -O0.  I tried compiling with -O2
> and these "size of symbol changed" warnings went away.  Strange.
Hmm, -O0 turns them on for me too.  This appears to be something to do with
template instantiation.  If I recompile just the two files it's complaining
about (cac.o and udpiiu.o) with -O0 then I get even more warnings from the
later ldppc runs.  It feels like the linker is comparing the sizes of the
instantiated template in the named .o file with another one, and warning if
they're different.  Maybe the new one isn't being compiled with the same
optimization level?
HTH.  I would encourage you to look at upgrading to vxWorks 5.5.2 though, I
have a lot more confidence in its compiler.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
"Size of symbol changed" warnings building EPICS Base 3.14.12.2 J. Lewis Muir
Prev: RE: BOY FAQ Chen, Xihui
Next: Re: 5500 temp monitor Re: mvme6100 HW issues? Kate Feng
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: "Size of symbol changed" warnings building EPICS Base 3.14.12.2 Dirk Zimoch
Next: Re: "Size of symbol changed" warnings building EPICS Base 3.14.12.2 Dirk Zimoch
