1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ASYN Communication through windows serial port (via USB)
To: Josh Stein <[email protected]>, "[email protected]" <[email protected]>
Date: Sat, 3 Mar 2012 23:02:23 -0800 (PST)
Did you test the driver/hardware installation of your USB to serial device?
You may have several USB port, COM3 not be the one you are connected to.
Emmanuel
----- Original Message -----
To: [email protected]
Cc:
Sent: Friday, March 2, 2012 2:03 PM
Subject: ASYN Communication through windows serial port (via USB)
Boy how I hate bringing this stuff up on a Friday...
I have a need to communicate to a serial based instrument off of a windows laptop. I have the latest ASYN build, which supports COM port mapping for windows. Like any 'modern' laptop, this machine does not have any built in serial connections, so I have a USB adapter which maps COM3 to a serial port. I can talk to the device via a terminal program on machine.
I execute the following on a softIOC running on the windows box:
drvAsynSerialPortConfigure("L0","COM3",0,0,0,0)
asynSetOption("L0",0,"baud","115200")
setOption failed COM3 error calling GetCommConfig 87
Note the setOption failed error; this is (apparently) preventing me from setting the baud rate to 115.2K (which, of course, is what the external device needs). (As an aside, I contacted Mark Rivers and he pointed out the typo in the error message - it should read: "...error calling SetCommConfig...")
I know this adapter handles that baud rate, as I can set it via a terminal program and communicate to my external device.
Any ideas?
Re: ASYN Communication through windows serial port (via USB) S. Stein
ASYN Communication through windows serial port (via USB) Josh Stein
Prev: Re: mvme6100 HW issues? Kate Feng
Next: Re: ASYN Communication through windows serial port (via USB) S. Stein
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: ASYN Communication through windows serial port (via USB) Josh Stein
