Yes, I have successfully talked to the device with a terminal program running on the same windows box.
----- Original Message -----
To: "Josh Stein" <[email protected]>, [email protected]
Sent: Sunday, March 4, 2012 1:02:23 AM
Subject: Re: ASYN Communication through windows serial port (via USB)
Did you test the driver/hardware installation of your USB to serial device?
You may have several USB port, COM3 not be the one you are connected to.
Emmanuel
To: [email protected]
Cc:
Sent: Friday, March 2, 2012 2:03 PM
Subject: ASYN Communication through windows serial port (via USB)
Boy how I hate bringing this stuff up on a Friday...
I have a need to communicate to a serial based instrument off of a windows laptop. I have the latest ASYN build, which supports COM port mapping for windows. Like any 'modern' laptop, this machine does not have any built in serial connections, so I have a USB adapter which maps COM3 to a serial port. I can talk to the device via a terminal program on machine.
I execute the following on a softIOC running on the windows box:
drvAsynSerialPortConfigure("L0","COM3",0,0,0,0)
asynSetOption("L0",0,"baud","115200")
setOption failed COM3 error calling GetCommConfig 87
Note the setOption failed error; this is (apparently) preventing me from setting the baud rate to 115.2K (which, of course, is what the external device needs). (As an aside, I contacted Mark Rivers and he pointed out the typo in the error message - it should read: "...error calling SetCommConfig...")
I know this adapter handles that baud rate, as I can set it via a terminal program and communicate to my external device.
Any ideas?
- Re: ASYN Communication through windows serial port (via USB) Emmanuel Mayssat
RE: ASYN Communication through windows serial port (via USB) Mark Rivers
<2012>
2025
2026
<2012>
2025
2026
