I am trying to use your Tektronix TDS-3000 support on win32-x86. And I have found that it neither works via "Direct network connection" nor "GPIB/LAN connection": ERROR: vxi11Configure is not supported on WIN32 Is there a possibility to talk to the TDS 3054C device any other way on win32? If so, could you give me a hint? If using "Remote serial port", the following errors occur: drvAsynIPPortConfigure("L0", "172.20.92.3", 0, 0, 0) st.cmd -- Line 50 -- Command drvAsynIPPortConfigure not found. asynOctetSetInputEos("L0",0,"\n") Port L0 connectDevice failed: asynManager:connectDevice port L0 not found asynOctetSetOutputEos("L0",0,"\n") Port L0 connectDevice failed: asynManager:connectDevice port L0 not found -- Best regards, Pavel Maslov, MS Controls Engineer at Pulsed power Lab Efremov Institute for Electro-Physical Apparatus St. Petersburg, Russia Mobile: +7 (951) 672 22 19 Phone: +7 (812) 461 01 01
| ANJ, 18 Nov 2013 |
Home
News
About
Talk
Base
Modules
Extensions
