1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: TDS 3000 on win32-x86
To: Pavel Masloff <[email protected]>, EPICS Tech Talk <[email protected]>, "Nicholas P. DiMonte" <[email protected]>
Date: Mon, 5 Mar 2012 14:38:23 +0000
Hi Pavel,
This error
ERROR: vxi11Configure is not supported on WIN32
is expected because there is no support for VXI-11 on win32-x86, because we don't have an implementation of Sun RPC for win32-x86, which the VXI-11 support requires.
However, this error:
drvAsynIPPortConfigure("L0", "172.20.92.3", 0, 0, 0)
st.cmd -- Line 50 -- Command drvAsynIPPortConfigure not found.
is not expected.  The drvAsynIPPortConfigure command works fine on win32-x86.  You must have a mistake in building your application, perhaps you forgot to include "drvAsynIPPort.dbd" in your dbd file.
From: [email protected] [[email protected]] on behalf of Pavel Masloff [[email protected]]
Sent: Monday, March 05, 2012 8:31 AM
To: EPICS Tech Talk; Nicholas P. DiMonte
Subject: TDS 3000 on win32-x86
Hi Nick et al. :
I am trying to use your Tektronix TDS-3000 support on win32-x86. And I have found that it neither works via "Direct network connection" nor "GPIB/LAN connection":
Is there a possibility to talk to the TDS 3054C device any other way on win32? If so, could you give me a hint?
If using "Remote serial port", the following errors occur:
asynOctetSetInputEos("L0",0,"\n")
Port L0 connectDevice failed: asynManager:connectDevice port L0 not found
asynOctetSetOutputEos("L0",0,"\n")
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Phone: +7 (812) 461 01 01
TDS 3000 on win32-x86 Pavel Masloff
Prev: TDS 3000 on win32-x86 Pavel Masloff
Next: Re: Problems with priorities in epicsThreadCreate: Thank you. Goetz Pfeiffer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: TDS 3000 on win32-x86 Pavel Masloff
