Subject: |
Converting driver of R3.13 Applications to R3.14 problems |
"Bai Jiaoni" <[email protected]> |
To: |
[email protected] |
Date: |
Thu, 8 Mar 2012 22:33:46 +0800 (CST) |
Hello
I write a driver for Epics 3.13, but now I need to use it for epics 3.14. I
add some items in <top>/exampleApp/src/Makefile as follows:
TOP=../..
include $(TOP)/configure/CONFIG
# ADD MACRO DEFINITIONS AFTER THIS LINE
# Only build for "hard" IOC's
ifneq ($(findstring Host, $(VALID_BUILDS)),)
VALID_BUILDS = Host
endif
# Build an IOC support library
LIBRARY_IOC += xxxSupport
# xxxRecord.h will be created from xxxRecord.dbd
DBDINC += xxxRecord
# install devXxxSoft.dbd into <top>/dbd
DBD += xxxSupport.dbd
# The following are compiled and added to the Support library
xxxSupport_SRCS += xxxRecord.c
xxxSupport_SRCS += devXxxSoft.c
xxxSupport_LIBS += $(EPICS_BASE_IOC_LIBS)
# build an ioc application
PROD_IOC = example
# example.dbd will be created and installed
DBD += example.dbd
# example.dbd will be made up from these files:
example_DBD += base.dbd
example_DBD += xxxSupport.dbd
example_DBD += dbSubExample.dbd
example_DBD += exampleHello.dbd
example_DBD += BPEM.dbd
# <name>_registerRecordDeviceDriver.cpp will be created from <name>.dbd
example_SRCS += example_registerRecordDeviceDriver.cpp
example_SRCS_DEFAULT += exampleMain.cpp
example_SRCS_vxWorks += -nil-
# Add locally compiled object code
example_SRCS += dbSubExample.c
example_SRCS += exampleHello.c
example_SRCS += drvBPEM.c
example_SRCS += devBPEM.c
example_SRCS += universe.c
example_SRCS += dmaLib.c
# The following adds support from base/src/vxWorks
example_OBJS_vxWorks += $(EPICS_BASE_BIN)/vxComLibrary
example_LIBS += xxxSupport
# NOTE: To build SNL programs, SNCSEQ must be defined
# in the <top>/configure/RELEASE file
ifneq ($(SNCSEQ),)
# This builds sncExample as a component of example
example_SNCFLAGS += +r
example_DBD += sncExample.dbd
example_SRCS += sncExample.stt
example_LIBS += seq pv
# The following builds sncProgram as a standalone application
PROD_HOST += sncProgram
sncProgram_SNCFLAGS += +m
sncProgram_SRCS += sncProgram.st
sncProgram_LIBS += seq pv
sncProgram_LIBS += $(EPICS_BASE_HOST_LIBS)
endif
example_LIBS += $(EPICS_BASE_IOC_LIBS)
include $(TOP)/configure/RULES
# ADD RULES AFTER THIS LINE
When I make in <top>/, it reports error
../drvBPEM.c:26:21: vxWorks.h: No such file or directory
../drvBPEM.c:27:19: vxLib.h: No such file or directory
../drvBPEM.c:28:17: vme.h: No such file or directory
../drvBPEM.c:29:23: rebootLib.h: No such file or directory
../drvBPEM.c:30:21: taskLib.h: No such file or directory
../drvBPEM.c:31:20: sysLib.h: No such file or directory
../drvBPEM.c:32:20: logLib.h: No such file or directory
../drvBPEM.c:33:20: intLib.h: No such file or directory
../drvBPEM.c:34:16: iv.h: No such file or directory
But when I add items as follows, there exits no error.
VALID_BUILDS = Host
endif
But I don't know what is the function of these codes and why these codes can solve
my prolem.
Besides my host architechture is linux-x86 and cross complier target architecture is
vxworks ppc604. I think maybe VALID_BUILDS = Ioc is suitable for vxworks, but there
still exits the errors in this case. I don't know why.
Thank you.
Jiaoni Bai
Institute of High Energy Physics, CAS
NO.13 of Yuquan Road Haidian, Beijing China
- Re: Converting driver of R3.13 Applications to R3.14 problems Andrew Johnson
How do you close a CSS BOY window? Xinyu.Wu
Re: How to corretly read the INP field? Andrew Johnson
<2012>
2025
2026
RE: How do you close a CSS BOY window? Chen, Xihui
<2012>
2025
2026
