Subject: Re: Converting driver of R3.13 Applications to R3.14 problems
To: [email protected]
Cc: Bai Jiaoni <[email protected]>
Date: Thu, 8 Mar 2012 18:03:49 -0600
Hello,
On 2012-03-08 Bai Jiaoni wrote:
> When I make in <top>/, it reports error
> ../drvBPEM.c:26:21: vxWorks.h: No such file or directory
> ../drvBPEM.c:27:19: vxLib.h: No such file or directory
> ../drvBPEM.c:28:17: vme.h: No such file or directory
> ../drvBPEM.c:29:23: rebootLib.h: No such file or directory
> ../drvBPEM.c:30:21: taskLib.h: No such file or directory
> ../drvBPEM.c:31:20: sysLib.h: No such file or directory
> ../drvBPEM.c:32:20: logLib.h: No such file or directory
> ../drvBPEM.c:33:20: intLib.h: No such file or directory
> ../drvBPEM.c:34:16: iv.h: No such file or directory
These errors are because it's trying to compile vxWorks-specific code using
the linux native compiler, which is never going to work since Linux doesn't
have those header files.
> Besides my host architechture is linux-x86 and cross complier target
>  architecture is vxworks ppc604. I think maybe VALID_BUILDS = Ioc is
>  suitable for vxworks, but there still exits the errors in this case. I
>  don't know why.
You don't need to look at or set VALID_BUILDS at all, take that modification
out completely.
Assuming your added source files are only meant to be compiled for vxWorks,
the changes you need to make are that instead of these lines:
example_SRCS += drvBPEM.c
example_SRCS += devBPEM.c
example_SRCS += universe.c
example_SRCS += dmaLib.c
use these instead:
example_SRCS_vxWorks += drvBPEM.c
example_SRCS_vxWorks += devBPEM.c
example_SRCS_vxWorks += universe.c
example_SRCS_vxWorks += dmaLib.c
which tell the build system that these files should only be compiled for the
vxWorks target architectures.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
Converting driver of R3.13 Applications to R3.14 problems Bai Jiaoni
Prev: RE: How do you close a CSS BOY window? Chen, Xihui
Next: example_registerRecordDeviceDriver.cpp:238: undefined reference to `pvar_drvet_drvBPEM' error Bai Jiaoni
Prev: Converting driver of R3.13 Applications to R3.14 problems Bai Jiaoni
