Hi Zen,
I suspect you did not set the asynInt32ArrayMask bit to the asynPortDriver constructor, telling it that your driver will implement that interface.
The 64-bit issue is not a problem, FTVL=LONG means 32-bit integer in EPICS.
Sent: Friday, March 09, 2012 1:40 PM
To: Mark Rivers; [email protected]
Subject: RE: Here is a Message
Hi Mark,
No, it is a different problem.
The error is generated by doCallbacksInt32Array(), which is not called at interrupt level.
I notice that there is something wrong with my waveform record to which the callback is supposed to put data.
record(waveform,"$(P):WF:DATA"){
field( DTYP, "asynInt32ArrayIn")
field( INP, "@asyn($(PORT),0,1)WF_DATA")
field( SCAN, "I/O Intr")
field( NELM, "16")
field( FTVL, "LONG")
field( PINI, "1")
At IOC init time I get this message, I don't understand why:
devAsynInt32Array::initCommon, TEST1:GADC0:WF:DATA find asynInt32Array interface failed.
There is reference in my .dbd file to asynInt32ArrayIn.
In a different device driver and a different IOC I use the same record with Float32 and that IOC works.
As somewhat different and related issue, I wonder what will happen when I build and run this code on a 64 bit machine. I wonder if field( FTVL,"LONG") means that on 64 bit each element will be 8 bytes long? If so there may be trouble.
Zen
> -----Original Message-----
> From: Mark Rivers [mailto:[email protected]]
> Sent: Friday, March 09, 2012 11:11 AM
> To: Szalata, Zenon M.; [email protected]
> Hi Zen,
> This message makes me wonder if you are doing asyn callbacks at interrupt
> level? If so, you should not do that, you should have your interrupt routine
> signal another thread which does the asyn callbacks.
> > interrupt: errlogPrintf called from interrupt level
> Mark
> From: [email protected] [[email protected]] on
> behalf of Szalata, Zenon M. [[email protected]]
> Sent: Friday, March 09, 2012 12:59 PM
> To: [email protected]
> Subject: Here is a Message
> While modifying and testing a device driver subclassed from asynPortDriver for
> a VME module I am getting this message:
> A call to 'assert(status == epicsMutexLockOK)'
> by thread 'cbLow' failed in ../../asyn/asynDriver/asynManager.c line 2222.
> EPICS Release EPICS R3.14.11 $R3-14-11$ $2009/08/28 18:47:36$.
> Local time is 2012-03-09 10:52:43.182719160 PUS
> Please E-mail this message to the author or to [email protected]
> Calling epicsThreadSuspendSelf()
> Thread cbLow (0x1692b30) suspended
> I am using asyn R4.17.
> I am sending this message because the message tells me to.
> I will comment out my recent modifications and try to pinpoint which part of
> my device driver is responsible.
> Thanks,
> Zen
- RE: Here is a Message Szalata, Zenon M.
- Here is a Message Szalata, Zenon M.
- RE: Here is a Message Mark Rivers
<2012>
2025
2026
<2012>
2025
2026
