Subject: RE: Here is a Message
To: "Szalata, Zenon M." <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 9 Mar 2012 20:58:13 +0000
This one is simple I think.  Your driver has not implemented the readInt32Array method.  You don't need to implement that if your record is only I/O Intr scanned, but if it is periodically scanned you need to implement it.
Sent: Friday, March 09, 2012 2:31 PM
To: Mark Rivers; [email protected]
Hi Mark,
Yes, I needed to add the mask.  So now that error is gone but I have a new one:
2012/03/09 11:48:48.618 TEST1:GADC0:WF:DATA devAsynInt32Array::callbackWf read error asynPortDriver:readArray not implemented
I guess today is not my day.  I am still missing something in my device driver...
I am looking at two other similar driver modules that I have implemented some time ago, which are using this type of code and I just can't see what I am missing.
> -----Original Message-----
> From: Mark Rivers [mailto:[email protected]]
> Sent: Friday, March 09, 2012 11:43 AM
> To: Szalata, Zenon M.; [email protected]
> Hi Zen,
> I suspect you did not set the asynInt32ArrayMask bit to the asynPortDriver
> constructor, telling it that your driver will implement that interface.
> The 64-bit issue is not a problem, FTVL=LONG means 32-bit integer in EPICS.
> Mark
> From: Szalata, Zenon M. [[email protected]]
> Sent: Friday, March 09, 2012 1:40 PM
> Hi Mark,
> No, it is a different problem.
> The error is generated by doCallbacksInt32Array(), which is not called at
> interrupt level.
> I notice that there is something wrong with my waveform record to which the
> callback is supposed to put data.
> record(waveform,"$(P):WF:DATA"){
>   field( DTYP, "asynInt32ArrayIn")
>   field( INP,  "@asyn($(PORT),0,1)WF_DATA")
>   field( SCAN, "I/O Intr")
>   field( NELM, "16")
>   field( FTVL, "LONG")
>   field( PINI, "1")
> At IOC init time I get this message, I don't understand why:
> devAsynInt32Array::initCommon, TEST1:GADC0:WF:DATA find asynInt32Array
> interface failed.
> There is reference in my .dbd file to asynInt32ArrayIn.
> In a different device driver and a different IOC I use the same record with
> Float32 and that IOC works.
> As somewhat different and related issue, I wonder what will happen when I
> build and run this code on a 64 bit machine.  I wonder if field( FTVL,"LONG")
> means that on 64 bit each element will be 8 bytes long?  If so there may be
> trouble.
> Thanks,
> Zen
> > Sent: Friday, March 09, 2012 11:11 AM
> > Hi Zen,
> > This message makes me wonder if you are doing asyn callbacks at interrupt
> > level?  If so, you should not do that, you should have your interrupt routine
> > signal another thread which does the asyn callbacks.
> > >  interrupt: errlogPrintf called from interrupt level
> > Mark
> > From: [email protected] [[email protected]] on
> > behalf of Szalata, Zenon M. [[email protected]]
> > Sent: Friday, March 09, 2012 12:59 PM
> > To: [email protected]
> > Subject: Here is a Message
> > While modifying and testing a device driver subclassed from asynPortDriver
> for
> > a VME module I am getting this message:
> > A call to 'assert(status == epicsMutexLockOK)'
> >     by thread 'cbLow' failed in ../../asyn/asynDriver/asynManager.c line 2222.
> > EPICS Release EPICS R3.14.11 $R3-14-11$ $2009/08/28 18:47:36$.
> > Local time is 2012-03-09 10:52:43.182719160 PUS
> > Please E-mail this message to the author or to [email protected]
> > Calling epicsThreadSuspendSelf()
> > Thread cbLow (0x1692b30) suspended
> > I am using asyn R4.17.
> > I am sending this message because the message tells me to.
> > I will comment out my recent modifications and try to pinpoint which part of
> > my device driver is responsible.
> > Thanks,
> > Zen
RE: Here is a Message Szalata, Zenon M.
RE: Here is a Message Mark Rivers
Prev: RE: Here is a Message Szalata, Zenon M.
Next: Re: Invitation to test cothread.catools release candidate Matt Newville
Next: RE: Here is a Message Szalata, Zenon M.
