Subject: Re: ca_flush_io and threads
To: [email protected]
Cc: [email protected]
Date: Mon, 12 Mar 2012 10:56:52 +0100
Hi Michael,
If you have "third party" threads that have to work with CA, e.g. call ca_flush_io(), it is necessary that they join the main CA context. Otherwise they will start their own unrelated context.
Get a context handle from the main thread with ca_current_context() after calling ca_context_create(). Then in your third party thread, call ca_attach_context() with that context handle.
Dirk
[email protected] wrote:
I've just discovered that ca_flush_io() only appears to have an effect on IO requests generated by the calling thread and calling ca_flush_io() from an unrelated thread appears to be a no-op.  Is this deliberate?  I can't see any hint of this behaviour in the documentation, which uses the simple phrase "Flush outstanding IO requests to the server."  I was expecting the effect to be process wide.
RE: ca_flush_io and threads michael.abbott
Prev: ca_flush_io and threads michael.abbott
Next: RE: ca_flush_io and threads michael.abbott
