Subject: Fwd:
To: tech-talk <[email protected]>
Date: Mon, 12 Mar 2012 12:39:50 +0200
Hi All
I am trying to load a small epics application into the mvme2304 board
in VME crate. After following the instructions  from tutorial from
EPICS web site, (and running the "NBO" command from PPC-BUG of the
cpu,) I still do not find it is working.
I have copied the st.cmd file and the dbd and db directories to the
directory /tftpboot of the tftp server and also have included the
directory /tftpboot *(async,ro) in the /etc/exports file.
At the end I have pasted the messages from hyperterminal I am using to
configure the CPU for network boot. Please have a view and guide me
where can be the problem.
Copyright Motorola Inc. 1988 - 2001, All Rights Reserved
PPC1 Debugger/Diagnostics Release Version 5.2 - 07/20/01 RM01
COLD Start
Local Memory Found =08000000 (&134217728)
MPU Clock Speed =333Mhz
BUS Clock Speed =67Mhz
Reset Vector Location  : ROM Bank B
Mezzanine Configuration: Single-MPU
Current 60X-Bus Master : MPU0
Idle MPU(s)            : NONE
L2Cache:       NONE
System Memory: 128MB, ECC Enabled (ECC-Memory Detected)
PPC1-Bug>NIOT
Controller LUN =00?
Device LUN     =00?
Node Control Memory Address =07F9E000?
Client IP Address      =10.1.22.45?
Server IP Address      =10.1.22.58?
Subnet IP Address Mask =255.255.255.0?
Broadcast IP Address   =10.1.22.1?
Gateway IP Address     =0.0.0.0?
Boot File Name ("NULL" for None)     =/mvme2307/bin/RTEMS-mvme2307/mvme2307.boot
Argument File Name ("NULL" for None)
=10.1.22.58:/tftpboot/mvme2307/iocBoot/iocmvme2307/st.cmd?
10.1.22.58:/tftpboot/mvme2307/st.cmd
Boot File Load Address         =001F0000?
Boot File Execution Address    =001F0000?
Boot File Execution Delay      =00000000?
Boot File Length               =00000000?
Boot File Byte Offset          =00000000?
BOOTP/RARP Request Retry       =00?
TFTP/ARP Request Retry         =00?
Trace Character Buffer Address =00000000?
BOOTP/RARP Request Control: Always/When-Needed (A/W)=W?
BOOTP/RARP Reply Update Control: Yes/No (Y/N)       =Y?
Update Non-Volatile RAM (Y/N)? Y
PPC1-Bug>nbo
Network Booting from: DEC21140, Controller 0, Device 0
Device Name: /pci@80000000/pci1011,9@e,0:0,0
Loading: /mvme2307/bin/RTEMS-mvme2307/mvme2307.boot
Client IP Address      = 10.1.22.45
Server IP Address      = 10.1.22.58
Gateway IP Address     = 0.0.0.0
Subnet IP Address Mask = 255.255.255.0
Boot File Name         = /mvme2307/bin/RTEMS-mvme2307/mvme2307.boot
Argument File Name     = 10.1.22.58:/tftpboot/mvme2307/st.cmd
Network Boot File load in progress... To abort hit <BREAK>
Bytes Received =&1639816, Bytes Loaded =&1639816
Bytes/Second   =&149074, Elapsed Time =11 Second(s)
Residual-Data Located at: $07F88000
The display of hyperterminal do not continue after this. Also I am new
to PPC-Bug and VME, so I need guidance of what is the status
represented here.
With Thanks and Regards
ZIA
Control Engineer
Synchrotron-light for Experimental Sciences and Applications in the Middle
East (SESAME)
P. O. Box 7, Allan 19252, Jordan
Phone: +962-5-3511348 Ext: 239
Cell:     +962-79-5295527
Res:      +962-5-3511463
RE: Fwd: michael.abbott
Prev: RE: ca_flush_io and threads michael.abbott
Next: RE: Fwd: michael.abbott
