Subject: RE: Fwd:
To: <[email protected]>, <[email protected]>
Date: Mon, 12 Mar 2012 13:22:46 +0000
> I am trying to load a small epics application into the mvme2304 board
> in VME crate. After following the instructions  from tutorial from
> EPICS web site, (and running the "NBO" command from PPC-BUG of the
> cpu,) I still do not find it is working.
Alas, I am wholly unfamiliar with RTEMS, but a few obvious things spring to mind:
1. Is there a shell, do you know, built into your RTEMS image?
2. What serial settings are built into your RTEMS image?
3. Indeed, is your RTEMS image even built to use the right serial device?
Don't worry about EPICS until RTEMS boots...
Hopefully other people on this list have more of a clue about RTEMS.
Fwd: Qazi Zia-ul-Haque
Prev: Fwd: Qazi Zia-ul-Haque
Next: RE: Invitation to test cothread.catools release candidate michael.abbott
Next: RE: Fwd: michael.abbott
