Subject: RE: [Operating System platforms] which one do you use?
To: "'Pavel Masloff'" <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Tue, 13 Mar 2012 16:57:37 +0000
Hi Pavel,
Every site is different.
Here is what we do at our site:
- Run soft IOCs on Linux when possible.  This includes IOC that communicate with low-bandwidth hardware.
- Run soft IOCs on Windows when necessary.  This includes IOCs that control hardware for which only Windows support is provided by the vendor.  It also includes some high-bandwidth devices like GigE cameras where the GUI is running on a Windows machine, and we want the data to only go across the network once.  Thus we want the IOC to be running on the same machine as the GUI.
- We use Windows machines almost exclusively as the client machines.  This is typically because there is at least one piece of hardware (CCD detector, etc.) for which only Windows support is available.  But it is also because users are more familiar with Windows than Linux.
- Running X-windows based GUI clients across the network is fine for most applications.  But it does not work well for high-bandwidth applications like fast image displays.  For that, running a local client is much better.
From: [email protected] [mailto:[email protected]] On Behalf Of Pavel Masloff
Sent: Tuesday, March 13, 2012 7:35 AM
To: EPICS Tech Talk
Subject: [Operating System platforms] which one do you use?
Hello,
I would like to know which operating system do you guys use as the IOCs, and also on client machines? And why?
Do you switch off GUI on IOCs? Do you use virtual systems? And how do such systems influence the overall performance?
As for me, I'm currently using linux-x86 (Red Hat Enterprise Linux 5.5) run on a Virtual Machine, and win32-x86 (WinXP sp3) as a host system.
I want to put aside the virtualized linux system for awhile and install it as host. Am thinking about CentOS, since RHEL is not fully freeware.
Am I right in presuming that the Windows platform is more suitable for clients (CSS) rather than soft IOCs?
Any input would be greatly appreciated!
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
D.V. Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Phone: +7 (812) 461 01 01
[Operating System platforms] which one do you use? Pavel Masloff
Prev: RE: sysBusToLocalAdrs question Mark Rivers
Next: RE: [Operating System platforms] which one do you use? Mark Rivers
Prev: RE: [Operating System platforms] which one do you use? Di Maio Franck
Next: Re: [Operating System platforms] which one do you use? Emmanuel Mayssat
