Subject: RE: sysBusToLocalAdrs question
To: "'Bai Jiaoni'" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 13 Mar 2012 16:47:53 +0000
That is probably because your BSP is not providing access to the A32 address 0x600000.  What addresses in A32 address space does your BSP support?
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Bai Jiaoni
Sent: Tuesday, March 13, 2012 11:17 AM
To: [email protected]
Subject: sysBusToLocalAdrs question
Hello,I defind a structure as following.
typedef struct CARDINFO^M
{^M
    USHORT    cardnum;^M
    int       cardtype;                 /* to store card model */^M
    struct CARDINFO *next;^M
    int   magicHeader;^M
    volatile unsigned long      BaseAddr; /*DPB VME address*/^M
    volatile unsigned long      baseaddr; /*the address of DPB on cpu^M
     Board*/^M
    int                         ConfStatus;^M
    IOSCANPVT ioscanpvt;^M
    USHORT    vecnum;^M
    unsigned  intLevel;^M
    volatile unsigned long      FIFO_baseaddr;/*DPB FIFO VME address*/^M
    volatile unsigned long      fifoBuffer_;/*the address of DPB FIFO on cpu address*/^M
    unsigned int*  dmaRdstat;           /* dma read status */^M
^M
}CARDINFO;^M
But when I use sysBusToLocalAdrs(A32) as following ,it return status != OK. I do not know why. When I use A24, there exists no error. Why
if ((status = sysBusToLocalAdrs(VME_AM_EXT_SUP_DATA, 0x600000, (char**)&newcard->baseaddr))!=OK)
Jiaoni Bai
Institute of High Energy Physics, CAS
NO.13 of Yuquan Road Haidian, Beijing China
sysBusToLocalAdrs question Bai Jiaoni
Prev: EPICS Wiki upgraded and moved Andrew Johnson
Next: RE: [Operating System platforms] which one do you use? Mark Rivers
Prev: sysBusToLocalAdrs question Bai Jiaoni
Next: sysBusToLocalAdrs question Bai Jiaoni
