Subject: menuFtype for 64 bit integers aka. long long and unsigned long long
To: [email protected]
Date: Thu, 15 Mar 2012 14:10:42 +0100
I'm working on soft IOC that will need to deal with 64-bit numbers. Our Linux based instrument supports reading and writing 64 signed and unsigned values, both as scalars and as arrays.
Looking at menuFtype, there is no support for 64-bits. I would like to see "long long" and "unsigned long long" support in the menuFtype.
Are there any plans on adding support for 64-bit types to menuFtype (for 3.14.x branch)?
Are there any workarounds for this issue?
I guess this change would affect basic EPICS type handling code - not record, driver or device support code.
Best regards,
Hinko
Hinko Kocevar
Software development engineer
Instrumentation Technologies d.d.
Velika pot 22, SI-5250 Solkan - Slovenia
T:+386 5 3352600, F:+386 5 3352601
mailto: [email protected]
http://www.i-tech.si - When your users demand stability
The information transmitted is intended solely for the
addressee and may contain confidential and/or privileged
information. Any review, retention, disclosure or other use
by persons other than the intended recipient is prohibited.
If you received this in error, please notify the sender and
delete all copies.
Re: menuFtype for 64 bit integers aka. long long and unsigned long long Andrew Johnson
Prev: EPICS performance evaluation ssahoo
Next: waveform ENUM FTVL or BOOL FTVL Hinko Kocevar
Next: Re: menuFtype for 64 bit integers aka. long long and unsigned long long Andrew Johnson
