Subject: waveform ENUM FTVL or BOOL FTVL
To: [email protected]
Date: Thu, 15 Mar 2012 14:22:27 +0100
Our Linux OS based instrument will be running soft IOC. The instrument supports various data types. One of the data types that I have trouble supporting in EPICS is array of bool values. My intention was to use ENUM FTVL for waveform but the problem I'm seeing in the IOC shell is:
missing record support entry table Record Support Routine (get_enum_str) Record Type waveform PV h:b::adllr4:adc_module:dc_rej_bypass-I.VAL dbGet
I just wanted to confirm that for waveform record FTVL ENUM is indeed supported. What am I doing wrong?
Here is the PV definition:
record(waveform, "$(H)$(B):adllr4:adc_module:dc_rej_bypass-I")
        field(DESC, "TBD")
        field(INP, "boards.adllr4.adc_module.dc_rej_bypass")
        field(DTYP, "liberaGet")
        field(NELM, "9")
        field(FTVL, "ENUM")
Note that using other FTVL values works, but they are not "restrictive" enough to allow only '0'/'1' or 'false'/'true' values.
Best regards,
Hinko
Hinko Kocevar
Software development engineer
Instrumentation Technologies d.d.
Velika pot 22, SI-5250 Solkan - Slovenia
T:+386 5 3352600, F:+386 5 3352601
mailto: [email protected]
http://www.i-tech.si - When your users demand stability
The information transmitted is intended solely for the
addressee and may contain confidential and/or privileged
information. Any review, retention, disclosure or other use
by persons other than the intended recipient is prohibited.
If you received this in error, please notify the sender and
delete all copies.
Re: waveform ENUM FTVL or BOOL FTVL Tim Mooney
Prev: menuFtype for 64 bit integers aka. long long and unsigned long long Hinko Kocevar
Next: Re: ENV Variables in EDM Dirk Zimoch
Prev: Re: menuFtype for 64 bit integers aka. long long and unsigned long long Andrew Johnson
Next: Re: waveform ENUM FTVL or BOOL FTVL Tim Mooney
