Subject: Re: ENV Variables in EDM
To: "Szalata, Zenon M." <[email protected]>
Date: Thu, 15 Mar 2012 17:14:14 +0100
Hi Zen,
I am not familiar with EDM, but this looks like the shell, not EMD is executing "/opt/myarea/bin/$(ARCH)/command". For the shell, $(xxx) means: execute command "xxx" and use its stdout output as a value. Try ${ARCH} or $ARCH instead.
Dirk
Szalata, Zenon M. wrote:
I would like to be able to specify command path using an environment variable in the Shell Command widget.
For example I would like to have path like this:
where ARCH is an environment variable. In my case it can have value arch-32 or arch-64 value.
When I do that I get an error message:
sh: arch-32: No such file or directory
How can this be done?
Any help will be appreciated.
Zen
RE: ENV Variables in EDM Szalata, Zenon M.
Prev: waveform ENUM FTVL or BOOL FTVL Hinko Kocevar
Next: RE: Synchronising CA shut down Hill, Jeffrey O
Prev: ENV Variables in EDM Szalata, Zenon M.
Next: RE: ENV Variables in EDM Szalata, Zenon M.
