Subject: RE: ENV Variables in EDM
To: Dirk Zimoch <[email protected]>
Date: Thu, 15 Mar 2012 15:10:37 -0700
Hi Dirk,
Thank you for your suggestion.  I did not use it because John Sinclair offered an "EDM" solution:
use this form:
/opt/myarea/bin/<env:ARCH>/command
which works.
Zen
> -----Original Message-----
> From: Dirk Zimoch [mailto:[email protected]]
> Sent: Thursday, March 15, 2012 9:14 AM
> To: Szalata, Zenon M.
> Cc: [email protected]
> Subject: Re: ENV Variables in EDM
> Hi Zen,
> I am not familiar with EDM, but this looks like the shell, not EMD is
> executing "/opt/myarea/bin/$(ARCH)/command". For the shell, $(xxx)
> means: execute command "xxx" and use its stdout output as a value. Try
> ${ARCH} or $ARCH instead.
> Dirk
> Szalata, Zenon M. wrote:
> > I would like to be able to specify command path using an environment
> > variable in the Shell Command widget.
> > For example I would like to have path like this:
> > where ARCH is an environment variable.  In my case it can have value
> > arch-32 or arch-64 value.
> > When I do that I get an error message:
> > sh: arch-32: No such file or directory
> > How can this be done?
> > Any help will be appreciated.
> > Thanks,
> > Zen
ENV Variables in EDM Szalata, Zenon M.
Re: ENV Variables in EDM Dirk Zimoch
Prev: Re: waveform ENUM FTVL or BOOL FTVL Tim Mooney
Next: RE: Synchronising CA shut down michael.abbott
Prev: Re: ENV Variables in EDM Dirk Zimoch
Next: EPICS performance evaluation ssahoo
