Subject: Re: menuFtype for 64 bit integers aka. long long and unsigned long long
To: [email protected]
Date: Mon, 26 Mar 2012 09:06:02 -0600
Hi Hinko,
On 2012-03-26 Hinko Kocevar wrote:
> Our instrument natively uses 64-bit integers for some parameter, so I
> reckon that using casted epicsFloat64 back to integer 64 would not cut it.
> Right the only solution I see using two 32-bit integers in an array.
That is probably the best and safest solution, and I'd recommend making them
signed integers (DBF_LONG) not unsigned (DBF_ULONG) so you don't have any
problems with Channel Access which can pretend that DBF_ULONG values are
actually DBF_DOUBLE.  You can use the aSub record to transport and process
those arrays within the IOC, and I think the sequencer will also be able to
handle them properly.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
menuFtype for 64 bit integers aka. long long and unsigned long long Hinko Kocevar
RE: menuFtype for 64 bit integers aka. long long and unsigned long long Mark Rivers
Re: menuFtype for 64 bit integers aka. long long and unsigned long long Hinko Kocevar
Prev: RE: Alarm annunciation via email in CSS BEAST Kasemir, Kay
Next: Google Groups subscription to tech-talk? Andrew Johnson
Prev: Re: menuFtype for 64 bit integers aka. long long and unsigned long long Hinko Kocevar
Next: waveform ENUM FTVL or BOOL FTVL Hinko Kocevar
