Subject: RE: Build problem with db dependencies
To: Bruce Hill <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 20 Mar 2012 17:00:45 +1100
Hi Bruce,
Good timing - I just ran into the same problem today!  I agree, it's a pain to have to run 'make rebuild' every time.  Thanks for the patch, that works for me too.
Cheers,
Emma
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Bruce Hill
Sent: Saturday, 18 February 2012 11:31 AM
To: [email protected]
Subject: Build problem with db dependencies
Has anyone else run into a build dependency problem with base-3,14,12?
What I've been finding is that I can build an IOC or module that depends on
*.db or *.template files from another module successfully the first time, but
it fails on subsequent builds.
Example build output:
% make
perl /reg/g/pcds/package/epics/3.14/base/R3.14.12-0.4.0/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../..
perl /reg/g/pcds/package/epics/3.14/base/R3.14.12-0.4.0/bin/linux-x86_64/makeMakefile.pl O.RTEMS-beatnik ../../..
perl /reg/g/pcds/package/epics/3.14/base/R3.14.12-0.4.0/bin/linux-x86_64/makeMakefile.pl O.linux-x86 ../../..
mkdir O.Common
/usr/bin/make -C O.linux-x86_64 -f ../Makefile TOP=../../.. T_A=linux-x86_64 install
make[1]: Entering directory `/reg/neh/home/bhill/wa2/epics/iocTest/test-R3.14.12/evr1/myEvrApp/Db/O.linux-x86_64'
perl /reg/g/pcds/package/epics/3.14/base/R3.14.12-0.4.0/bin/linux-x86_64/makeDbDepends.pl ../O.Common/iocAdmin.db ../iocAdmin.substitutions >> iocAdmin.db.d
echo "../O.Common/iocAdmin.db : " >> iocAdmin.db.d
Inflating database from ../iocAdmin.substitutions
/reg/g/pcds/package/epics/3.14/extensions/current/bin/linux-x86/msi   -I. -I.. -I../O.Common -I ../../../db     -I/reg/g/pcds/package/epics/3.14/base/R3.14.12-0.4.0/db     -I/reg/g/pcds/package/epics/3.14/modules/autosave/R4.2.1.2-2.7.0/db -I/reg/g/pcds/package/epics/3.14/modules/iocAdmin/R3.0.0-1.6.0/db -I/reg/neh/home/bhill/wa2/trunk/pcds/epics/modules/event/current/db  -S../iocAdmin.substitutions > iocAdmin.tmp
mv iocAdmin.tmp ../O.Common/iocAdmin.db
perl /reg/g/pcds/package/epics/3.14/base/R3.14.12-0.4.0/bin/linux-x86_64/makeDbDepends.pl ../O.Common/evr.db ../evr.substitutions >> evr.db.d
echo "../O.Common/evr.db : " >> evr.db.d
Inflating database from ../evr.substitutions
/reg/g/pcds/package/epics/3.14/extensions/current/bin/linux-x86/msi   -I. -I.. -I../O.Common -I ../../../db     -I/reg/g/pcds/package/epics/3.14/base/R3.14.12-0.4.0/db     -I/reg/g/pcds/package/epics/3.14/modules/autosave/R4.2.1.2-2.7.0/db -I/reg/g/pcds/package/epics/3.14/modules/iocAdmin/R3.0.0-1.6.0/db -I/reg/neh/home/bhill/wa2/trunk/pcds/epics/modules/event/current/db  -S../evr.substitutions > evr.tmp
mv evr.tmp ../O.Common/evr.db
Installing created db file ../../../db/iocAdmin.db
Installing created db file ../../../db/evr.db
make[1]: Leaving directory `/reg/neh/home/bhill/wa2/epics/iocTest/test-R3.14.12/evr1/myEvrApp/Db/O.linux-x86_64'
/usr/bin/make -C O.RTEMS-beatnik -f ../Makefile TOP=../../.. T_A=RTEMS-beatnik install
make[1]: Entering directory `/reg/neh/home/bhill/wa2/epics/iocTest/test-R3.14.12/evr1/myEvrApp/Db/O.RTEMS-beatnik'
make[1]: Nothing to be done for `install'.
make[1]: Leaving directory `/reg/neh/home/bhill/wa2/epics/iocTest/test-R3.14.12/evr1/myEvrApp/Db/O.RTEMS-beatnik'
/usr/bin/make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install
make[1]: Entering directory `/reg/neh/home/bhill/wa2/epics/iocTest/test-R3.14.12/evr1/myEvrApp/Db/O.linux-x86'
make[1]: Leaving directory `/reg/neh/home/bhill/wa2/epics/iocTest/test-R3.14.12/evr1/myEvrApp/Db/O.linux-x86'
(232) 04:29 PM psusr115:~/wa2/epics/iocTest/test-R3.14.12/evr1/myEvrApp/Db
% make
make[1]: *** No rule to make target `ioc.db', needed by `../O.Common/iocAdmin.db'.  Stop.
make: *** [install.linux-x86_64] Error 2
The first build succeeds because RELEASE_DBFLAGS has a list of -I directives
which includes the released iocAdmin module's db dir, so msi is able to use that
to successfully build my iocAdmin.db file.
The problem arises because the first build also creates a dependency file
for iocAdmin.db using makeDbDepends.pl that looks like this.
% cat O.linux-x86_64/iocAdmin.db.d
../O.Common/iocAdmin.db: ioc.db access.db iocCluster.db
Subsequent builds fail because ioc.db is over in the released iocAdmin  module's db dir,
which doesn't end up on the vpath for .db files.
I think I have a fix for it, but I can't figure out why this hasn't been a problem for us
and others before now.
I'd like to avoid customizing my base configure files to the extent possible,
but these changes seem to fix the problem.
% svn diff
Index: CONFIG_APP_INCLUDE
--- CONFIG_APP_INCLUDE  (revision 8621)
+++ CONFIG_APP_INCLUDE  (working copy)
@@ -16,6 +16,8 @@
    RELEASE_INCLUDES += $$(addprefix -I,$$(wildcard $$(strip $$($(1)))/include))
    RELEASE_DBDFLAGS += $$(addprefix -I,$$(wildcard $$(strip $$($(1)))/dbd))
    RELEASE_DBFLAGS += $$(addprefix -I,$$(wildcard $$(strip $$($(1)))/db))
+  RELEASE_DIRS_DBD += $$(wildcard $$(strip $$($(1)))/dbd)
+  RELEASE_DIRS_DB  += $$(wildcard $$(strip $$($(1)))/db)
    RELEASE_PERL_MODULE_DIRS += $$(wildcard $$($(1)_LIB)/perl)
  endef
  $(foreach top, $(RELEASE_TOPS), $(eval $(call RELEASE_FLAGS_template,$(top)) ))
Index: RULES.Db
--- RULES.Db    (revision 8757)
+++ RULES.Db    (working copy)
@@ -11,10 +11,10 @@
  #####################################################  vpath
  vpath %.dbd $(USR_VPATH) $(GENERIC_SRC_DIRS) $(dir $(DBD))
-vpath %.db $(USR_VPATH) $(GENERIC_SRC_DIRS) $(dir $(DB))
-vpath %.vdb $(USR_VPATH) $(GENERIC_SRC_DIRS) $(dir $(DB))
+vpath %.db $(USR_VPATH) $(GENERIC_SRC_DIRS) $(dir $(DB)) $(RELEASE_DIRS_DB)
+vpath %.vdb $(USR_VPATH) $(GENERIC_SRC_DIRS) $(dir $(DB)) $(RELEASE_DIRS_DBD)
  vpath %.substitutions $(USR_VPATH) $(GENERIC_SRC_DIRS) $(COMMON_DIR)
-vpath %.template $(USR_VPATH) $(GENERIC_SRC_DIRS) $(COMMON_DIR)
+vpath %.template $(USR_VPATH) $(GENERIC_SRC_DIRS) $(COMMON_DIR) $(RELEASE_DIRS_DB)
  vpath bpt%.data $(USR_VPATH) $(GENERIC_SRC_DIRS) $(COMMON_DIR)
  vpath %.acf $(USR_VPATH) $(GENERIC_SRC_DIRS) $(COMMON_DIR)
  vpath %.acs $(USR_VPATH) $(GENERIC_SRC_DIRS) $(COMMON_DIR)
Any comments would be appreciated.
- Bruce
<br>This message and any attachments may contain proprietary or confidential information. If you are not the intended recipient or you received the message in error, you must not use, copy or distribute the message. Please notify the sender immediately and destroy the original message. Thank you.
Re: Build problem with db dependencies Ralph Lange
Re: Build problem with db dependencies Bruce Hill
Prev: Re: ARM - EPICS performance evaluation Emmanuel Mayssat
Next: ARM - EPICS performance evaluation ssahoo
Prev: Build problem with db dependencies Bruce Hill
Next: Re: Build problem with db dependencies Ralph Lange
