1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: asynDriver problem with vxi11
To: EPICS <[email protected]>
Date: Wed, 21 Mar 2012 11:15:53 +0100
Hi all,
I got an error message from asynDriver in vxi11Configure:
vxi11Configure("TWAL",     "172.20.2.89",           1,    0.0,"gpib0")
A call to 'assert(pgpibPvt)'
    by thread 'TWALSRQ' failed in ../asynGpib/asynGpib.c line 633.
EPICS Release EPICS R3.14.12.2 $Date: 2011/12/14 08:56:55 $.
Local time is 2012-03-21 10:00:02.078465710 CET
By looking into the code I found that the SRQ handler is called but pgpibPvt, which is taken from pasynUser->userPvt, is not set. I guess this may happen when a SRQ is already active when the port is configured and autoconnect is active.
I am using asyn 4-16.
Dirk
Prev: RE: Build problem with db dependencies Gougnaud Françoise
Next: Re: Build problem with db dependencies Bruce Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Support for Xantrex XDC 60-100? Wesley Moore
Next: hdf5 (h5py) anyone? Emmanuel Mayssat
