1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Build problem with db dependencies
Date: Wed, 21 Mar 2012 15:56:44 -0700
Hi Francoise,
Actually, now that you mention it, I only noticed
this problem after I merged the 3.14.12.2 updates
and the rules-db patch into our 3.14.12 base.
I haven't tried Ralph's one-liner perl fix, but the patch I
posted 2/17 works with our 3.14.12.2.   Just be sure to
get it from the original 2/17 post, as the quoted
version in the replies below has extra linefeeds
from being wrapped.
If it still doesn't work for you, take a look at the
<db_substitution_filename_root>.db.d files created in the
O.<target_arch>  directory.
It may also help to see what the generated RELEASE_DIRS_DB
variable looks like, which you can do by adding these lines
to the end of your Db/Makefile.
# After the include of $(TOP)/configure/RULES
install:   showvars
showvars:
     @echo RELEASE_DIRS_DB=$(RELEASE_DIRS_DB)
The character before the "@" must be a tab.
Then "make" or "make install" will print the value of RELEASE_DIRS_DB
which should be a list of all the target db directories for the modules
your ioc depends on.
If all else fails, try "make -d>  make.log" and examine
the resulting make.log file which should show make searching
for the missing db template in each directory on it's vpath.
That vpath should include the directories in $(RELEASE_DIRS_DB).
- Bruce
On 03/21/2012 01:37 AM, Gougnaud Françoise wrote:
I have exactly the same problem since I started using EPICS Base R3.14.12.2. I never had this problem before with R3.14.12.
None of the solutions discussed here works with R3.14.12.2. I also applied the patch contained in the R3.14.12.2 known problems without success.
Cheers,
-----Message d'origine-----
De : [email protected] [mailto:[email protected]] De la part de Ralph Lange
Envoyé : mardi 20 mars 2012 08:47
À : [email protected]
Objet : Re: Build problem with db dependencies
You can also try creating the dependencies correctly, e.g. by putting
$(COMMON_DIR)/%.db$(RAW)$(DEP): %.substitutions
         @$(RM) $@
         $(PERL) -e 'undef $$/; $$_=<>;
@d=m/(?:^|})\s*file\s+\"?([^\"{\s]*)\s*\{/mg; print
"$(COMMON_DIR)/$*.db$(RAW): @d\n";' $<  >  [email protected]
         $(MV) [email protected] $@
or something functionally equivalent into your RULES file.
Amazing how perl turns everything into an obvious one-liner, isn't it?
Cheers,
~Ralph
On Tue Mar 20 2012 07:00:45 GMT+0100 (CET), Emma Shepherd<[email protected]>  wrote:
Hi Bruce,
Good timing - I just ran into the same problem today!  I agree, it's a pain to have to run 'make rebuild' every time.  Thanks for the patch, that works for me too.
Cheers,
Emma
-----Original Message-----
[mailto:[email protected]] On Behalf Of Bruce Hill
Sent: Saturday, 18 February 2012 11:31 AM
To: [email protected]
Subject: Build problem with db dependencies
Has anyone else run into a build dependency problem with base-3,14,12?
What I've been finding is that I can build an IOC or module that
depends on *.db or *.template files from another module successfully
the first time, but it fails on subsequent builds.
Example build output:
% make
perl /reg/g/pcds/package/epics/3.14/base/R3.14.12-0.4.0/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../..
perl /reg/g/pcds/package/epics/3.14/base/R3.14.12-0.4.0/bin/linux-x86_64/makeMakefile.pl O.RTEMS-beatnik ../../..
perl /reg/g/pcds/package/epics/3.14/base/R3.14.12-0.4.0/bin/linux-x86_64/makeMakefile.pl O.linux-x86 ../../..
mkdir O.Common
/usr/bin/make -C O.linux-x86_64 -f ../Makefile TOP=../../..
T_A=linux-x86_64 install
make[1]: Entering directory `/reg/neh/home/bhill/wa2/epics/iocTest/test-R3.14.12/evr1/myEvrApp/Db/O.linux-x86_64'
perl
keDbDepends.pl ../O.Common/iocAdmin.db ../iocAdmin.substitutions>>  iocAdmin.db.d echo "../O.Common/iocAdmin.db : ">>  iocAdmin.db.d Inflating database from ../iocAdmin.substitutions
/reg/g/pcds/package/epics/3.14/extensions/current/bin/linux-x86/msi   -I. -I.. -I../O.Common -I ../../../db     -I/reg/g/pcds/package/epics/3.14/base/R3.14.12-0.4.0/db     -I/reg/g/pcds/package/epics/3.14/modules/autosave/R4.2.1.2-2.7.0/db -I/reg/g/pcds/package/epics/3.14/modules/iocAdmin/R3.0.0-1.6.0/db -I/reg/neh/home/bhill/wa2/trunk/pcds/epics/modules/event/current/db  -S../iocAdmin.substitutions>  iocAdmin.tmp
mv iocAdmin.tmp ../O.Common/iocAdmin.db perl
keDbDepends.pl ../O.Common/evr.db ../evr.substitutions>>  evr.db.d
echo "../O.Common/evr.db : ">>  evr.db.d Inflating database from ../evr.substitutions
/reg/g/pcds/package/epics/3.14/extensions/current/bin/linux-x86/msi   -I. -I.. -I../O.Common -I ../../../db     -I/reg/g/pcds/package/epics/3.14/base/R3.14.12-0.4.0/db     -I/reg/g/pcds/package/epics/3.14/modules/autosave/R4.2.1.2-2.7.0/db -I/reg/g/pcds/package/epics/3.14/modules/iocAdmin/R3.0.0-1.6.0/db -I/reg/neh/home/bhill/wa2/trunk/pcds/epics/modules/event/current/db  -S../evr.substitutions>  evr.tmp
mv evr.tmp ../O.Common/evr.db
Installing created db file ../../../db/iocAdmin.db Installing created
db file ../../../db/evr.db
make[1]: Leaving directory `/reg/neh/home/bhill/wa2/epics/iocTest/test-R3.14.12/evr1/myEvrApp/Db/O.linux-x86_64'
/usr/bin/make -C O.RTEMS-beatnik -f ../Makefile TOP=../../..
T_A=RTEMS-beatnik install
make[1]: Entering directory `/reg/neh/home/bhill/wa2/epics/iocTest/test-R3.14.12/evr1/myEvrApp/Db/O.RTEMS-beatnik'
make[1]: Nothing to be done for `install'.
make[1]: Leaving directory `/reg/neh/home/bhill/wa2/epics/iocTest/test-R3.14.12/evr1/myEvrApp/Db/O.RTEMS-beatnik'
/usr/bin/make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86
install
make[1]: Entering directory `/reg/neh/home/bhill/wa2/epics/iocTest/test-R3.14.12/evr1/myEvrApp/Db/O.linux-x86'
make[1]: Leaving directory `/reg/neh/home/bhill/wa2/epics/iocTest/test-R3.14.12/evr1/myEvrApp/Db/O.linux-x86'
(232) 04:29 PM
psusr115:~/wa2/epics/iocTest/test-R3.14.12/evr1/myEvrApp/Db
% make
make[1]: *** No rule to make target `ioc.db', needed by `../O.Common/iocAdmin.db'.  Stop.
make: *** [install.linux-x86_64] Error 2
The first build succeeds because RELEASE_DBFLAGS has a list of -I
directives which includes the released iocAdmin module's db dir, so
msi is able to use that to successfully build my iocAdmin.db file.
The problem arises because the first build also creates a dependency
file for iocAdmin.db using makeDbDepends.pl that looks like this.
% cat O.linux-x86_64/iocAdmin.db.d
../O.Common/iocAdmin.db: ioc.db access.db iocCluster.db
Subsequent builds fail because ioc.db is over in the released iocAdmin
module's db dir, which doesn't end up on the vpath for .db files.
I think I have a fix for it, but I can't figure out why this hasn't
been a problem for us and others before now.
I'd like to avoid customizing my base configure files to the extent
possible, but these changes seem to fix the problem.
% svn diff
Index: CONFIG_APP_INCLUDE
--- CONFIG_APP_INCLUDE  (revision 8621)
+++ CONFIG_APP_INCLUDE  (working copy)
@@ -16,6 +16,8 @@
     RELEASE_INCLUDES += $$(addprefix -I,$$(wildcard $$(strip $$($(1)))/include))
     RELEASE_DBDFLAGS += $$(addprefix -I,$$(wildcard $$(strip $$($(1)))/dbd))
     RELEASE_DBFLAGS += $$(addprefix -I,$$(wildcard $$(strip
$$($(1)))/db))
+  RELEASE_DIRS_DBD += $$(wildcard $$(strip $$($(1)))/dbd)
+ RELEASE_DIRS_DB  += $$(wildcard $$(strip $$($(1)))/db)
     RELEASE_PERL_MODULE_DIRS += $$(wildcard $$($(1)_LIB)/perl)
   endef
   $(foreach top, $(RELEASE_TOPS), $(eval $(call
RELEASE_FLAGS_template,$(top)) ))
Index: RULES.Db
--- RULES.Db    (revision 8757)
+++ RULES.Db    (working copy)
@@ -11,10 +11,10 @@
   #####################################################  vpath
   vpath %.dbd $(USR_VPATH) $(GENERIC_SRC_DIRS) $(dir $(DBD)) -vpath
%.db $(USR_VPATH) $(GENERIC_SRC_DIRS) $(dir $(DB)) -vpath %.vdb
+vpath %.db $(USR_VPATH) $(GENERIC_SRC_DIRS) $(dir $(DB))
+$(RELEASE_DIRS_DB) vpath %.vdb $(USR_VPATH) $(GENERIC_SRC_DIRS) $(dir
+$(DB)) $(RELEASE_DIRS_DBD)
   vpath %.substitutions $(USR_VPATH) $(GENERIC_SRC_DIRS) $(COMMON_DIR)
-vpath %.template $(USR_VPATH) $(GENERIC_SRC_DIRS) $(COMMON_DIR)
+vpath %.template $(USR_VPATH) $(GENERIC_SRC_DIRS) $(COMMON_DIR)
+$(RELEASE_DIRS_DB)
   vpath bpt%.data $(USR_VPATH) $(GENERIC_SRC_DIRS) $(COMMON_DIR)
   vpath %.acf $(USR_VPATH) $(GENERIC_SRC_DIRS) $(COMMON_DIR)
   vpath %.acs $(USR_VPATH) $(GENERIC_SRC_DIRS) $(COMMON_DIR)
Any comments would be appreciated.
- Bruce
<br>This message and any attachments may contain proprietary or confidential information. If you are not the intended recipient or you received the message in error, you must not use, copy or distribute the message. Please notify the sender immediately and destroy the original message. Thank you.
Bruce Hill
Member Technical Staff
SLAC National Accelerator Lab
2575 Sand Hill Road M/S 10
Menlo Park, CA  94025
RE: Build problem with db dependencies Gougnaud Françoise
Build problem with db dependencies Bruce Hill
RE: Build problem with db dependencies Emma Shepherd
Re: Build problem with db dependencies Ralph Lange
Prev: asynDriver problem with vxi11 Dirk Zimoch
Next: Re: menuFtype for 64 bit integers aka. long long and unsigned long long Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Build problem with db dependencies Gougnaud Françoise
Next: RE: Build problem with db dependencies Gougnaud Françoise
