1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: hdf5 (h5py) anyone?
To: Emmanuel Mayssat <[email protected]>, epics <[email protected]>
Date: Thu, 22 Mar 2012 17:42:07 +0000
>what does an 'extra service' mean?
>Are you talking about a client/server architecture?
yes. In short, you can consider it as the Channel Archiver extension/upgrade with
(one of) a new driver to the hdf5 backend.  As a result, conceptually everything
(including file structure) would be the same except several extensions like support
of the EPICS 4 structured data types. The type registry and associated topics will be
presented at the next EPICS meeting.
-Nikolay
Sent: Thursday, March 22, 2012 1:00 PM
To: Malitsky, Nikolay D; epics
Subject: Re: hdf5 (h5py) anyone?
> read/write issues, multi-file data processing, etc require the corresponding extra service.
An add-on piece of software you have to pay for?
Is there a web page (a pointer) that talks about those topics and their implementation?
(sample code?)
It turns out a good starting point may be
http://www.hdfgroup.org/hdf5-quest.html#GENERAL
Although you may not have the answer yet, has anyone though (at least conceptually) of a h5 tree structure (database) design for archiving?
Would that be time based? (tree node like /date/20120315)
Would that be hardware based? (/chassis_id/device_type/device_id)
Would that be PV name base? (archiving of  AAA:BBB:CCC pv is located at /AAA/BBB/CCC )
Would that be subsystem based? ( /injector/solenoids/I:SO01/current )
the last 3 at once with links?
E
Re: hdf5 (h5py) anyone? Matt Newville
hdf5 (h5py) anyone? Emmanuel Mayssat
RE: hdf5 (h5py) anyone? Malitsky, Nikolay D
Re: hdf5 (h5py) anyone? Emmanuel Mayssat
Prev: Re: hdf5 (h5py) anyone? Emmanuel Mayssat
Next: Re: hdf5 (h5py) anyone? Pete R. Jemian
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: hdf5 (h5py) anyone? Matt Newville
