1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: hdf5 (h5py) anyone?
To: "Malitsky, Nikolay D" <[email protected]>
Cc: epics <[email protected]>
Date: Thu, 22 Mar 2012 13:44:01 -0500
Nikolay, Emmanuel,
On Thu, Mar 22, 2012 at 12:42 PM, Malitsky, Nikolay D <[email protected]> wrote:
>>what does an 'extra service' mean?
>>Are you talking about a client/server architecture?
> yes. In short, you can consider it as the Channel Archiver extension/upgrade
> with
> (one of) a new driver to the hdf5 backend.  As a result, conceptually
> everything
> (including file structure) would be the same except several extensions like
> support
> of the EPICS 4 structured data types. The type registry and associated
> topics will be
> presented at the next EPICS meeting.
I would be very cautious about archiving data directly into HDF5.  See:
     http://www.hdfgroup.org/hdf5-quest.html#gconc1
     http://www.hdfgroup.org/hdf5-quest.html#grdwt
Saving to some more robust format (say, ASCII files such as SDDS or a
relational database), and then converting to HDF5 for fast and
hierarchical read access is probably a much safer approach.
Whether hierarchical vs relational data storage is the better model
for an archiving system where the principle axis is time is an
interesting theoretical topic, but I think that archiving directly to
HDF5 is very likely to end up with lost data.
HDF5 is great at what it does, but it is not really a database
management system.
Cheers,
--Matt Newville
hdf5 (h5py) anyone? Emmanuel Mayssat
RE: hdf5 (h5py) anyone? Malitsky, Nikolay D
Re: hdf5 (h5py) anyone? Emmanuel Mayssat
Prev: RE: hdf5 (h5py) anyone? Mark Rivers
Next: RE: menuFtype for 64 bit integers aka. long long and unsigned long long Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: hdf5 (h5py) anyone? Malitsky, Nikolay D
Next: RE: hdf5 (h5py) anyone? Mark Rivers
