Subject: RE: About "dbCaMonitorLink" ?
To: "[email protected]" <[email protected]>, EPICS tech-talk <[email protected]>
Date: Wed, 28 Mar 2012 01:42:05 +0000
I think you can just do:
record(ai, "pressure_in_torr")
    field(DTYP, "Soft Channel")
    field(INP, "loek_current CP MS")
CP means process this record whenever a channel access monitor is received on the INP link PV.
From: [email protected] [[email protected]] on behalf of [email protected] [[email protected]]
Sent: Tuesday, March 27, 2012 7:59 PM
To: EPICS tech-talk
Subject: About "dbCaMonitorLink" ?
Dear All;
I have a question on dbCaLink.
Suppose an IOC has a PV like this:
    field(INP, "loek_current")
and another IOC has the referred PV something like this:
record(ai, "leak_current")
    field(SCAN, ".1 second")
    field(DTYP, "SOME_DEVICS")
    field(INP, "@some:address")
In this situation, the referring PV, "pressure_in_torr",
also needs to be scanned periodically to get the value
from "leak_current" through dbCaGetLink.
I'm wondering if I could use monitor function of CA to
transfer the data between the two IOCs so as not to cause
unnecessary traffic on the network. As far as I know,
there is no function something like "dbCaMonitorLink".
Is there any way to realize what I want to do?
I appreciate any comments and suggestions.
Thanks a lot in advance.
Jun-ichi Odagiri (KEK)
Re: About "dbCaMonitorLink" ? jun-ichi.odagiri
Prev: About "dbCaMonitorLink" ? jun-ichi.odagiri
Next: Re: About "dbCaMonitorLink" ? jun-ichi.odagiri
