Subject: Re: About "dbCaMonitorLink" ?
To: "Mark Rivers" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Wed, 28 Mar 2012 10:48:22 +0900
Dear Mark;
Thanks a lot for your quick response!
I should have been more careful in reading the manual before
posting the question.
Thank you again.
Best regards,
J. Odagiri
----- Original Message -----
> I think you can just do:
> record(ai, "pressure_in_torr")
>     field(DTYP, "Soft Channel")
>     field(INP, "loek_current CP MS")
> CP means process this record whenever a channel access monitor is
received on the INP link PV.
> Mark
> From: [email protected] [[email protected]] on
behalf of [email protected] [[email protected]]
> Sent: Tuesday, March 27, 2012 7:59 PM
> To: EPICS tech-talk
> Subject: About "dbCaMonitorLink" ?
> Dear All;
> I have a question on dbCaLink.
> Suppose an IOC has a PV like this:
>     field(INP, "loek_current")
> and another IOC has the referred PV something like this:
> record(ai, "leak_current")
>     field(SCAN, ".1 second")
>     field(DTYP, "SOME_DEVICS")
>     field(INP, "@some:address")
> In this situation, the referring PV, "pressure_in_torr",
> also needs to be scanned periodically to get the value
> from "leak_current" through dbCaGetLink.
> I'm wondering if I could use monitor function of CA to
> transfer the data between the two IOCs so as not to cause
> unnecessary traffic on the network. As far as I know,
> there is no function something like "dbCaMonitorLink".
> Is there any way to realize what I want to do?
> I appreciate any comments and suggestions.
> Thanks a lot in advance.
> Jun-ichi Odagiri (KEK)
About "dbCaMonitorLink" ? jun-ichi.odagiri
RE: About "dbCaMonitorLink" ? Mark Rivers
Prev: RE: About "dbCaMonitorLink" ? Mark Rivers
Next: Re: Build problem with db dependencies Bruce Hill
Next: Extract a column of data from 2D Waveform Record Peter Milne
