Subject: Re: What is void* puser in ca_create_channel
To: <[email protected]>
Date: Fri, 30 Mar 2012 15:57:35 +0200
On Thursday, March 29, 2012, Hill, Jeffrey O wrote:
> > How does this parameter have to look like?
> > Can I use a C-Struct with any member I want to have (even members which
> > are not for the CA, but for another part of my program)? Are there any
> > members which are mandatory? (like value or chid)
> A pointer to any data structure can be used. The CA library does not in
> any way access, or place any restrictions on the content of, this user
> application private data structure. The user application is of course
> responsible for allocation, initialization, maintenance, and
> de-allocation (proper cleanup) of this data structure.
> Use of void pointers passed to callbacks is an old technique which is
> roughly equivalent to a virtual function in modern software interfaces,
> BTW.
To give it some perspective, it is a low-level implementation technique for
what in high-level languages is automatically available when creating what
is commonly referred to as a 'closure'.
Cheers
Ben
Attachment: signature.asc
Description: This is a digitally signed message part.
What is void* puser in ca_create_channel Florian Feldbauer
RE: What is void* puser in ca_create_channel Hill, Jeffrey O
Prev: Re: another build problem with db dependencies Benjamin Franksen
Next: RE: What is void* puser in ca_create_channel Hill, Jeffrey O
Prev: RE: What is void* puser in ca_create_channel Hill, Jeffrey O
Next: ../testServer.cpp:672: warning: converting to 'int' from 'double' Dirk Zimoch
