Subject: Re: casStrmClient.cc error: invalid channel identifier
To: [email protected]
Cc: Emmanuel Vettoor <[email protected]>
Date: Mon, 2 Apr 2012 09:55:10 -0600
Hi Emma,
I'm not an expert in either the Gateway or sscan & saveData, but:
On 2012-04-01 Emma Shepherd wrote:
> We are using Gateway Version 2.0.3.0 and EPICS base 3.14.9 running on
>  CentOS 4.4.  Has anybody been looking into this issue yet?
There is a fairly important piece of functionality missing from those versions
of the Gateway and CAS library; to properly pass ca_put_callback() operations
through it you really need to upgrade to Gateway 2.0.4.0 on Base 3.14.11 or
later.  Now I can't actually find any calls to ca_put_callback() in a few of
the versions of the sscan and saveData code we have installed here, so I don't
know if an upgrade might fix this or not, but I might be missing something in
how that client works and it might still be trying to use that functionality
somehow.
Are both of the IOCs also built against Base 3.14.9 or are they using a later
version?
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
casStrmClient.cc error: invalid channel identifier Emma Shepherd
Prev: Re: What is void* puser in ca_create_channel Florian Feldbauer
Next: Re: casStrmClient.cc error: invalid channel identifier Tim Mooney
Prev: RE: casStrmClient.cc error: invalid channel identifier Hill, Jeffrey O
Next: asyn w/serial device pushing data Fong, Nia W.
