Subject: Re: casStrmClient.cc error: invalid channel identifier
Cc: [email protected], Emmanuel Vettoor <[email protected]>
Date: Mon, 2 Apr 2012 11:15:27 -0500 (CDT)
Hi Emma,
Mark is right that saveData is not a sequence program.  It's just straight C code.
Can you say more about the nature of the ioc crash?  Does it cease to function completely,
does the saveData task get suspended, do unrelated CA tasks also have problems?
I think I can narrow the scope a little bit.  If saveData has a connection through a PV gateway, I think it must be to one of what saveData calls "extra" PVs - PVs named in saveData.req, which are read once per scan.
If so, there are only two CA calls that can have occurred: ca_search() and ca_array_get_callback().  ca_search() is only called during saveData's initialization, so this is probably a ca_array_get_callback().  saveData doesn't use a connection callback, though it does check that the chid is nonzero before calling ca_array_get_callback().
It's pretty common at APS for saveData to connect to an "extra" PV through a gateway.  I'm not sure how common it is for the ioc hosting such a PV to be rebooted, though I think I've seen it happen personally a few tens of times over the last decade or so.
Tim
----- Original Message -----
To: "Emma Shepherd" <[email protected]>, [email protected]
Cc: "Emmanuel Vettoor" <[email protected]>
Sent: Monday, April 2, 2012 7:39:06 AM
Subject: RE: casStrmClient.cc error: invalid channel identifier
I don't think saveData is actually a sequence program, but it is a channel access client.  That may be important for tracking down the problem.
From: [email protected] [[email protected]] on behalf of Emma Shepherd [[email protected]]
Sent: Monday, April 02, 2012 12:01 AM
To: [email protected]
Cc: Emmanuel Vettoor
Sorry, I missed a possibly important bit of information - the CA client in the IOC is actually the sscan saveData sequence program.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Emma Shepherd
Sent: Monday, 2 April 2012 11:29 AM
Subject: casStrmClient.cc error: invalid channel identifier
I'm trying to track down the cause of an intermittent IOC crash, and came across launchpad bug 730720 which seems to be related (although in our case it doesn't involve CAJ clients).
Our symptoms are that when an IOC is rebooted, another IOC that has CA links to PVs served by that IOC through a gateway dies.  I believe that this happens on reboot of several different IOCs, not just one in particular.
We get the following error messages in the gateway log:
<snip>
Mar 18 07:09:11 Warning: Virtual circuit disconnect SR00IOC10.accelerator.synchrotron.org.au:5064
CAS Request: ics on sr05id01ioc01: cmd=2 cid=31 typ=0 cnt=1 psz=0 avail=101
CAS:
Mar 18 07:09:19 !!! Errlog message received (message is above) bad resource id in "../../../../src/cas/generic/casStrmClient.cc" at line 1810
Mar 18 07:09:19 !!! Errlog message received (message is above) filename="../../../../src/cas/generic/st/casStreamOS.cc" line number=582 Bad resource identifier - unexpected problem with client's input - forcing disconnect
Mar 18 07:09:19 !!! Errlog message received (message is above) </snip>
And the following message in the IOC that subsequently dies:
<snip>
CA.Client.Exception...............................................
    Error: "Invalid channel identifier"
    Context: "host=10.114.10.246:5064 ctx=Bad Resource ID=31 detected at ../../../../src/cas/generic/casStrmClient.cc.1810"
    Current Time: Sun Mar 18 2012 07:09:19.697135000 </snip>
A reboot of the IOC is enough to fix it, the gateway itself doesn't need to be restarted.
We are using Gateway Version 2.0.3.0 and EPICS base 3.14.9 running on CentOS 4.4.  Has anybody been looking into this issue yet?
Emma
<br>This message and any attachments may contain proprietary or confidential information. If you are not the intended recipient or you received the message in error, you must not use, copy or distribute the message. Please notify the sender immediately and destroy the original message. Thank you.
Tim Mooney ([email protected]) (630)252-5417
Software Services Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
RE: casStrmClient.cc error: invalid channel identifier Emma Shepherd
RE: casStrmClient.cc error: invalid channel identifier Mark Rivers
Prev: Re: casStrmClient.cc error: invalid channel identifier Andrew Johnson
Next: asyn w/serial device pushing data Fong, Nia W.
Prev: RE: casStrmClient.cc error: invalid channel identifier Mark Rivers
Next: RE: casStrmClient.cc error: invalid channel identifier Emma Shepherd
