Hi Matt,
Support for Modbus data types 4-10 were only added in Modbus R2-4, which is in beta release. Previous versions do not support signed 16-bit integers, only unsigned.
You can get the 2-4beta1 version at:
http://cars.uchicago.edu/software/pub/modbusR2-4beta1.tgz
I'd like to release it soon, so if you could test if it works for your application that would be great.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of [email protected]
Sent: Thursday, April 05, 2012 12:51 PM
To: [email protected]
Subject: reading negative 16-bit numbers over Asyn modbus
I have a Eurotherm 3217 controller that I'm talking to using modbus RTU over RS485 (via a Moxa terminal server). It seems to work fine, but I'm having trouble reading a negative number.
The Asyn support is configured to use modbus function code 3, like this: (from the eurotherm2k support module eurothermModbus.c):
mkname(str, strmaxlen, asynPortName, modbusAddress, loopNumber, 0, "PV");
asynRet = drvModbusAsynConfigure(str, asynPortName, modbusAddress,
MODBUS_READW, loopStart+PV_OFFSET, 3,
0, EUROTHERM_POLL_MS, "");
Where:
loop number is 1.
modbus addr is 1.
MODBUS_READW is 3 (this is the function code, so it's reading 16-bit words).
loopStart+PV_OFFSET is 1+0, so 1.
3 is the modbus length, which means 3*16-bit.
The 0 data type is Unsigned 16-bit binary integers.
This works fine for positive numbers, but negative fails. I tried changing the modbus data type to 4, which should mean INT16 2's complement, but it seems to fail at some point and just return zero in the record.
If I turn on asyn trace, the negative word I am reading back is "fd 1c". The actual reading I expect is about -750. So this looks to be correct if assuming 2's complement encoding.
Anybody successfully read negative integers over modbus?
I'm using modbus 2-2, and asyn 4-14.
Update... looking at drvModbusAsyn.c, I see that convertFromBinary() only implements 3 types of type conversion (modbus data types 1, 2 and 3 in the list in the documentation?)
Cheers,
Matthew
Dr Matthew Pearson
Senior Software Systems Engineer
Diamond Light Source
Chilton, Didcot
OX11 0DE
UK
MX Controls Team Leader
Beamline Controls - I19, I24, B24
- RE: reading negative 16-bit numbers over Asyn modbus matthew.pearson
- reading negative 16-bit numbers over Asyn modbus matthew.pearson
<2012>
2025
2026
<2012>
2025
2026
