Subject: Channel Access problem over SSH
To: EPICS Tech Talk <[email protected]>
Date: Sat, 7 Apr 2012 10:18:49 +0400
Hello tech-talkers,
There is an example IOC on a linux machine (Fedora 16) with an IP-address 172.20.92.99/16:
$EPICS_CA_ADDR_LIST=172.20.92.99
$EPICS_CA_AUTO_ADDR_LIST=NO
Which means I can access PVs on the same machine where the IOC is running. It works. No problem.
Now, when I connect to the linux machine via SSH from another machine on the same subnet (Windows XP, Putty), and when I run the IOC from the SSH client, then I get the following message in epics shell (over Putty) every once in a while:
online_notify.c:CA beacon (send to "172.20.255.255:5065") error was "Connection refused"
Still the IOC is running, I can caget, caput, camonitor. The Firewall is off. What might be the case?
Pavel
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Phone: +7 (812) 461 01 01
RE: Channel Access problem over SSH Hill, Jeffrey O
Prev: Re: asynPortDriver, I/O INTR and missing updates Eric Norum
Next: RE: asynPortDriver, I/O INTR and missing updates Mark Rivers
Prev: RE: asynPortDriver, I/O INTR and missing updates Mark Rivers
Next: RE: Channel Access problem over SSH Hill, Jeffrey O
