Subject: RE: Channel Access problem over SSH
To: Pavel Masloff <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Mon, 9 Apr 2012 12:59:14 +0000
Hi Pavel,
online_notify.c:CA beacon (send to "172.20.255.255:5065") error was "Connection refused"
This probably indicates that the IOC’s IP kernel is unable locate a route to the beacon address 172.20.255.255.
To avoid  this type of warning messages, one can modify the CA server beacon destination addresses, independent of the search message destination addresses, using EPICS_CA_AUTO_BEACON_ADDR_LIST and EPICS_CA_BEACON_ADDR_LIST. The server configuration chapter in the CA Reference Manual has some of the details.
Jeff
From: [email protected] [mailto:[email protected]] On Behalf Of Pavel Masloff
Sent: Saturday, April 07, 2012 12:19 AM
To: EPICS Tech Talk
Subject: Channel Access problem over SSH
Hello tech-talkers,
There is an example IOC on a linux machine (Fedora 16) with an IP-address 172.20.92.99/16:
$EPICS_CA_ADDR_LIST=172.20.92.99
$EPICS_CA_AUTO_ADDR_LIST=NO
Which means I can access PVs on the same machine where the IOC is running. It works. No problem.
Now, when I connect to the linux machine via SSH from another machine on the same subnet (Windows XP, Putty), and when I run the IOC from the SSH client, then I get the following message in epics shell (over Putty) every once in a while:
Still the IOC is running, I can caget, caput, camonitor. The Firewall is off. What might be the case?
Pavel
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Phone: +7 (812) 461 01 01
Re: Channel Access problem over SSH Pavel Masloff
Prev: Goodbye and thanks for all the fish Rarback, Harvey M.
Next: does CSS (CAJ?) support CA over an ssh tunnel Peter Milne
Prev: Channel Access problem over SSH Pavel Masloff
Next: Re: Channel Access problem over SSH Pavel Masloff
