1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Proposed support for additional Modbus data types
To: "'haquin'" <[email protected]>
Cc: Eric Norum <[email protected]>, tech-talk <[email protected]>
Date: Wed, 11 Apr 2012 14:25:37 +0000
I believe the error messages you are getting at init are because you have set noAutoConnect flag=1 in drvAsynIPPortConfigure:
drvAsynIPPortConfigure("AR-GT7-PC3","172.16.150.13:502",0,1,1)
In modbus versions prior to R2-1 noAutoConnect=1 was the recommended setting.  However, beginning in R2-1 automatic connection was fixed, and so it should be used.  You should change this to:
drvAsynIPPortConfigure("AR-GT7-PC3","172.16.150.13:502",0,0,1)
The errors at exit are probably because the underlying ports have been closed before the modbus poller is disabled.  I will look into this, but it is not serious.
-----Original Message-----
Sent: Wednesday, April 11, 2012 8:28 AM
To: Mark Rivers
Cc: Eric Norum; tech-talk
Subject: Re: Proposed support for additional Modbus data types
Hi Mark,
I have tested your R2-4beta2 version, the problem with SCAN=I/O Intr on asynInt32 arrays is solved.
The FLOAT32_LE writing with ao was in fact working fine, I forgot to issue a command to trig the consign update ...
everythings works fine
However, I have those messages at IOC init and exit and I don't know what to think about them :
modbusInterposeConfig("AR-GT7-PC3",0,5000)
drvModbusAsynConfigure("AR-GT7-PC3:Read_All",       "AR-GT7-PC3", 255,  4 , 0 , 46 , 0 ,  200 , "InterfaceIocaste")
drvModbusAsynConfigure("AR-GT7-PC3:ReadFLE",        "AR-GT7-PC3", 255,  4 , 9 ,  2 , 0 ,  200 , "InterfaceIocaste")
drvModbusAsynConfigure("AR-GT7-PC3:Write_IConsFLE", "AR-GT7-PC3", 255, 16 , 5 ,  2 , 0 ,   1 , "InterfaceIocaste")
2012/04/11 15:04:00.827 drvModbusAsyn::doModbusIO port AR-GT7-PC3:Read_All is disconnected
2012/04/11 15:04:00.828 drvModbusAsyn::doModbusIO port AR-GT7-PC3:ReadFLE is disconnected
2012/04/11 15:04:00.828 drvModbusAsyn::doModbusIO port AR-GT7-PC3:Write_IConsFLE is disconnected
drvModbusAsynConfigure("AR-GT7-PC3:Write_IRampFLE", "AR-GT7-PC3", 255, 16 , 1 ,  2 , 0 ,   1 , "InterfaceIocaste")
drvModbusAsynConfigure("AR-GT7-PC3:Write_Cmd",      "AR-GT7-PC3", 255,  6 , 0 ,  1 , 0 ,   1 , "InterfaceIocaste")
iocAlimHzrLx > exit
2012/04/11 15:04:41.098 drvModbusAsyn::doModbusIO port AR-GT7-PC3:ReadFLE error calling writeRead,
error=172.16.150.13:502 disconnected:, nwrite=0/6, nread=0
2012/04/11 15:04:41.114 drvModbusAsyn::doModbusIO port AR-GT7-PC3:Read_All error calling writeRead,
2012/04/11 15:04:41.300 drvModbusAsyn::doModbusIO port AR-GT7-PC3:ReadFLE has I/O error
2012/04/11 15:04:41.315 drvModbusAsyn::doModbusIO port AR-GT7-PC3:Read_All has I/O error
Le 06/04/2012 22:14, Mark Rivers a écrit :
> Hi,
> I was able to reproduce the problem with SCAN=I/O Intr on asynInt32 arrays crashing.  I have found and fixed the problem.
> Here is the patch:
> corvette:modbus/modbusApp/src>svn diff -r14638:14653 drvModbusAsyn.c
> Index: drvModbusAsyn.c
> --- drvModbusAsyn.c     (revision 14638)
> +++ drvModbusAsyn.c     (revision 14653)
> @@ -1371,8 +1371,9 @@
>                       break;
>                   /* Need to copy data to epicsInt32 buffer for callback */
> +                pasynManager->getAddr(pInt32Array->pasynUser,&offset);
>                   for (i=0; i<pPlc->modbusLength; i++) {
> -                    status = readPlcInt(pPlc, offset,&int32Data[i]);
> +                    status = readPlcInt(pPlc, offset+i,&int32Data[i]);
>                   asynPrint(pPlc->pasynUserTrace, ASYN_TRACE_FLOW,
>                             "%s::readPoller, calling client %p"
> I am unable to reproduce the problem with writing FLOAT32_LE values.  I can write them to the Modbus slave simulator and display the correct floating point value.
> These are the lines from my test startup script:
> # Word access at Modbus address 0
> # Access 60 words as inputs.
> # Function code=3
> # default data type unsigned integer.
> # drvModbusAsynConfigure("portName", "tcpPortName", slaveAddress, modbusFunction, modbusStartAddress, modbusLength, dataType, pollMsec, "plcType")
> drvModbusAsynConfigure("A0_In_Word", "sim1", 0, 4, 0, 60, 0, 2000, "Simulator")
> # Access 60 words as outputs.
> # Either function code=6 (single register) or 16 (multiple registers) can be used, but 16
> # is better because it is "atomic" when writing values longer than 16-bits.
> # Default data type unsigned integer.
> drvModbusAsynConfigure("A0_Out_Word", "sim1", 0, 16, 100, 10, 7, 1, "Simulator")
> These are the lines from the substitutions file:
> # These are the A0 inputs done with word access
> file "../../db/intarray_in.template" { pattern
> {P,           R,                PORT,     OFFSET,   DATA_TYPE,  NELM,    SCAN}
> {SIM1:,    LI:UINT16,        A0_In_Word,     0,     UINT16,       46,   "I/O Intr"}
> file "../../db/aoFloat64.template" { pattern
> {P,           R,               PORT,      OFFSET,   DATA_TYPE,    LOPR, HOPR, PREC}
> {SIM1:,    AO:FLOAT32_LE,    A0_Out_Word,    6,     FLOAT32_LE,   -1e6,  1e6,    3}
> I have created a new beta release, R2-4beta2.  You can get it here via Subversion:
> https://subversion.xor.aps.anl.gov/synApps/modbus/tags/R2-4beta2/
> Or here via a tar file:
> http://cars.uchicago.edu/software/pub/modbusR2-4beta2.tgz
> Please let me know if it fixes your crashing problem.
> Also, please tell me the actual error with your FLOAT32_LE ao record problem.  Are you sure that Modbus offset 5 is correct.  That is an odd number, and I would expect the 32-bit floating point registers might be located at even 16-bit word offsets, i.e. either 4 or 6, not 5.  Remember, when you specify the offset of the 32-bit floating point value you specify it in units of 16-bit Modbus registers, not in units of 32-bit registers.
> Cheers,
> Mark
> From: haquin [mailto:[email protected]]
> Sent: Friday, April 06, 2012 9:47 AM
> To: Eric Norum
> Cc: tech-talk; Mark Rivers
> Hi,
> - I don't understand why the Linux IOC crash is not reproducible ...
> so now the behaviour is the same on both Linux and VxWorks:
> Data in the waveform are equal to zero if scan is I/O Intr
> Data are correct in the waveform if scan is periodic
> - I've successfully tested the read INT32_LE function.
> I don't manage to write a FLOAT32_LE:
> here is my record:
> record(ao, "$(EQPT):TstICons") {
>     field(SCAN, "Passive")
>     field(DTYP, "asynFloat64")
>     field(OUT, "@asyn($(EQPT):Write_IConsFLE 0)FLOAT32_LE")
> here is my drvModbusAsynConfigure:
> drvModbusAsynConfigure("AR-GT7-PC3:Write_IConsFLE", "AR-GT7-PC3", 255, 16 , 5 ,  2 , 7 ,   1 , "InterfaceIocaste")
> do you see any incorrect setting ?
> Regards
> Le 05/04/2012 17:25, Eric Norum a écrit :
>> On Apr 5, 2012, at 7:19 AM, haquin wrote:
>>> Hi Mark,
>>> I started to test the new release R2-4 of your modbus driver,
>>> 1/ I have a regression problem:
>>> in case of "intarray_in" when scan mode is I/O Intr:
>>> Linux IOC crashes with segmentation error message
>> Could you run this again under GDB and send a stack trace?
>>> VxWorks IOC doesn't crash but data in the waveform are equal to zero
>>> On Linux if I start with the scan mode set to none there is no crash.
>> What happens if you change the mode to I/O Intr after the IOC has started?
>>> In both cases linux and VxWorks,
>>> if I change the scanning mode to any periodic scan (with a caput in the SCAN field), I do retreive correct data.
>>> drvModbusAsynConfigure("AR-GT7-PC3:Read_All",    "AR-GT7-PC3", 255,  4 , 0 , 46 , 0 ,  2000 , "InterfaceIocaste")
>>> here is my waveform:
>>> record(waveform, "$(EQPT):ReceiveModbusTable") {
>>>    field(DTYP, "asynInt32ArrayIn")
>>>    field(FLNK, "$(EQPT):TrigModbusTableProcessing")
>>>    field(INP, "@asyn($(EQPT):Read_All 0)MODBUS_DATA")
>>>    field(NELM, "46")
>>>    field(FTVL, "LONG")
>>>    field(SCAN, "I/O Intr")
>>> 2/ I have tested the retreival of float32_LE with ai record, this is ok
>>> tomorrow I'll test retreival of int32 and also he writting.
>>> best regards.
Proposed support for additional Modbus data types Mark Rivers
RE: Proposed support for additional Modbus data types Mark Rivers
Re: Proposed support for additional Modbus data types haquin
Re: Proposed support for additional Modbus data types Eric Norum
Prev: Re: Proposed support for additional Modbus data types haquin
Next: RE: What is void* puser in ca_create_channel Hill, Jeffrey O
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Proposed support for additional Modbus data types Eric Norum
