Subject: |
Re: procServ softIOC server - V2.6.0 released |
Ralph Lange <[email protected]> |
To: |
EPICS Tech Talk <[email protected]> |
Date: |
Tue, 17 Apr 2012 12:01:00 +0200 |
On 16.04.2012 18:44, Pavel Masloff wrote:
Ralph, when I try to start a bat file using procServ
under Windows 7 then I get this:
C:\Users\Maslick\Downloads>procServ -L test2.txt 50010
c:\epics\apps\LINAC\startIoc.bat
procServ: Error - Please change permissions on
c:\epics\apps\LINAC\startIoc.bat to at least ---x--x--x
procServ is not able to continue without execute permission
How can I set the bat file to be executable? Its attributes say
it's Full access (R,W).
Pavel,
on native Windows file systems, Cygwin has to fake the permission
info for files. So, obviously, the calls return no x bits for batch
files. (Which makes sense, in a way.)
I am usually starting the softIOC binary directly, which does not
create such a problem.
If you need to use a batch file, you might have to start command.com
(which is a real executable) with the batch file as first argument.
You could also try specifying command.com as the executable using
the command line option.
Good luck!
~Ralph
ps. Please drop me a line if you get it working, so I can add the
solution to the README.
- Re: procServ softIOC server - V2.6.0 released Dirk Zimoch
- procServ softIOC server - V2.6.0 released Ralph Lange
- Re: procServ softIOC server - V2.6.0 released Pavel Masloff
- Re: procServ softIOC server - V2.6.0 released Ralph Lange
Re: 9th NOBUGS conference announcement Hartman, Steven M.
log message filter in Asyn matthew.pearson
<2012>
2025
2026
<2012>
2025
2026
ANJ, 18 Nov 2013 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
