1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: log message filter in Asyn
To: [email protected]
Date: Tue, 17 Apr 2012 10:00:42 -0500
Hi Matthew,
On 2012-04-17 [email protected] wrote:
> Is there any interest in having a log message filter down in the Asyn
> layer?
Just making sure you know that you can turn off console error log message
output if you want to: The IOC command 'eltc 0' disables all errlogPrintf()
output on the console, and 'eltc 1' turns it back on again. The acronym stands
for Errors Logged To Console; it does not stop messages being sent to the
iocLogServer.  If you're trying to stem a fire-hose of error messages while
debugging this is usually all you need.
HTH,
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
RE: log message filter in Asyn Mark Rivers
log message filter in Asyn matthew.pearson
Prev: How to debug record processing? Nerses Gevorgyan
Next: Re: Channel Access problem over SSH Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: log message filter in Asyn matthew.pearson
Next: RE: log message filter in Asyn Mark Rivers
