1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: How to debug record processing?
To: [email protected]
Date: Tue, 17 Apr 2012 18:20:55 +0400
Dear EPICS experts,
I'm using a custom record which is enhanced version of subroutine record (has more output fields). The record is not processed, besides it has a "2 second" set in the SCAN field.
The scanppl doesn't show it has my custom records in the list.
The printouts I made in the $EPICS_BASE/src/db/dbAccess.c:dbProcess(struct dbCommon *precord) are not showing up. Which means dbProcess is not reached either. The PACT field shows value 0. Setting it to 1 using caput doesn't seems to change the value.
At the same time the function from INAM field of record is called successfully and works fine.
Do You have a clue, how can I find out why dbProcess and consequently my function supplied by SNAM is not called?
With Thanks in Advance,
Nerses
Prev: RE: Channel Access problem over SSH michael.abbott
Next: Re: log message filter in Asyn Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: log message filter in Asyn Eric Norum
Next: Re: How to debug record processing? Andrew Johnson
