Hi Nerses,
Have you tried using the aSub record type? It provides up to 21 input fields
A..U and output fields VALA..VALU which do not have to be arrays, you can just
set the array sizes to 1 (which is the default anyway) and use them as
scalars. You will need to make some minor changes to your subroutine code in
the way that it accesses the fields though; prec->a is now a pointer to the
value in the A field, so you have to use something like *(double *)prec->a if
FTA is DOUBLE for example. There is documentation in the record reference
manual at
https://wiki-ext.aps.anl.gov/epics/index.php/RRM_3-14_Array_Subroutine
HTH,
- Andrew
On 2012-04-17 Nerses Gevorgyan wrote:
> Dear EPICS experts,
> I'm using a custom record which is enhanced version of subroutine record
> (has more output fields).
> The record is not processed, besides it has a "2 second" set in the SCAN
> field.
> The scanppl doesn't show it has my custom records in the list.
> The printouts I made in the
> $EPICS_BASE/src/db/dbAccess.c:dbProcess(struct dbCommon *precord) are
> not showing up. Which means dbProcess is not reached either.
> The PACT field shows value 0. Setting it to 1 using caput doesn't seems
> to change the value.
> At the same time the function from INAM field of record is called
> successfully and works fine.
> Do You have a clue, how can I find out why dbProcess and consequently my
> function supplied by SNAM is not called?
> With Thanks in Advance,
> Nerses
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
Re: log message filter in Asyn Eric Norum
RE: log message filter in Asyn nick.rees
<2012>
2025
2026
How to debug record processing? Nerses Gevorgyan
hardware register access Bai Jiaoni
<2012>
2025
2026
