1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: hardware register access
To: [email protected]
Date: Tue, 17 Apr 2012 23:38:08 +0800 (CST)
I can not use A32 address 0x20600000 to access hardware register immediately After I download vxworks from server to mvme5100. But at this moment if I execute the special function whose work is as following, I can use 0x20600000 to access the hardware register. Can you give me some idear from the information provided about what this function do to help register access successfully?
------------Now begin to start the server----------
the host server IP is: 0.0.0.0
the host server PORT is: 2005
>>Create the server basic socket successfully!
>>The Watch Dog has been Created , ID=33478656
Initializing D32 cblt transfers  /*CBLTinit function */
>>The DCTL after configure is 820100   /* DMAinit function*/ DCTL:DMA transfer control register
>>The MISC status reg before modify is 40060000
>>The MISC Control reg before modify is 52060000
>>The VSI1_CTL reg is e0f20080
>>The VCSR_SET reg is 0
>>the LCLSIZE in MISC status reg is 40000000
>>The VCSR_SET reg after modify is 0
>>The VSI1_CTL reg after modify is e0f20000
>>The MISC status reg after modify is 40060000
>>The MISC Control reg after modify is 52060000
>>CBLT Software Configuration Done!
Receiving interrupt test signal
Awaiting interrupt!
>>Bind the server basic socket successfully!
>>The server basic socket begins to listen!
Server Socket is Listenning!
...Awaiting Connection>>>>>>>>
>>Function Socket Accepted successfully!
>>Check Socket Accepted successfully!
>>CBLT Socket Accepted successfully!
INFO : Func socket connected info Sent.
INFO : Check socket connected info Sent.
INFO : CBLT socket connected info Sent.
>>Server Function socket accept successfully!
.....Server Task number: 1
>>CBLT Data Acquisition Task Created Successfully!
>>Server Function socket connected to client successfully!
.....Client IP is: 192.168.0.198
.....Client PORT is: 1302
>>Function Socket Connection Checking Task Entered successfully !
>>Awaiting PC command!
>>PC command : Slot Select Configure!
>>Configure Data Received!
INFO : Slot Pack Information:
----Token=2000
----Slot 2-> 6: 0, 0, 0, 0, 1
----Slot 7-> 11: 0, 0, 0, 0, 0
----Slot 12->16: 0, 0, 0, 0, 0
----Slot 17->21: 0, 0, 0, 0, 0
------ The slot of DPB is 6!>>Entered PPC Real Configuration Process of Slot Sel
ect Conf!
>>VME:: Basic Global Address Configure.
VME:: Constant Address Set.
VME:: Board Base Address Configuration:
The fee board positions are:
6 th position
The sum of feemodules is 1
write <0x60> to <0x37ffdb> successfully!!
write <0x0> to <0x37ffdf> successfully!!
----Slot 6 : Geo= 0x00000006, A24: phy:0x00300000, A32: 0x00600000
Slot Select Info Configured Successfully!
Jiaoni Bai
Institute of High Energy Physics, CAS
NO.13 of Yuquan Road, Shijingshan District, Beijing, China
Re: hardware register access Andrew Johnson
Prev: RE: Channel Access problem over SSH Hill, Jeffrey O
Next: Re: log message filter in Asyn Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: How to debug record processing? Andrew Johnson
Next: Re: hardware register access Andrew Johnson
